My 1988 Cadillac Cimarron 2.8L M.P.F.I Car Runs Great. Dies sometimes at stop signs.
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By tj86cimarron
Cadillac Catera and Cimarron Forum Discussion, My 1988 Cadillac Cimarron 2.8L M.P.F.I Car Runs Great. Dies sometimes at stop signs. in Past Cadillac Vehicle Discussion; My 1988 Cadillac Cimarron 2.8L M.P.F.I Car Runs Great; but Dies sometimes at stop signs; but never dies when I ...
    seattlelion's Avatar
    seattlelion is offline Cadillac Owners Member
    Automobile(s): 1988 Cadillac Cimarron
    Jul 2013
    Seattle
    59
    QuestionMy 1988 Cadillac Cimarron 2.8L M.P.F.I Car Runs Great. Dies sometimes at stop signs.
    My 1988 Cadillac Cimarron 2.8L M.P.F.I Car Runs Great; but Dies sometimes at stop signs; but never dies when I have my A/C on. At idle at times the engine slightly decreases and increases idle at around 100 rpm variation; but not all the time. Sporatic. Seems like some vacuum leak; but I checked every vacuum related item under the hood and found no vaccum leaks. Like said when i run my A/C it idles perfect and never dies at all. I'm beginning to think it's something under the dashboard with the A/C vacuum controlled parts when the unit is turned off is possibly having a slight vacuum leak. Do any of you know the A/C system enough on this car that you can tell me what it is that will cause a vacuum leak in the A/C system only when it's turned off? The Vin is W for my 2.8L Engine.
    All these parts I replaced listed below in the last year and recent also; but I did not replace them over this problem I am having now. I have been restoring the cars parts due to the milage for preventive measures for my own comfort level. I love this car so I have been restoring it mechanically, electrically, etc. I want to keep this car no matter what others think about these Cimarrons.
    I replaced the ECM, Fuel Injectors, Fuel Pump Relay, Fuel Pump MAP Sensor, IAC Motor, TPS Sensor, Crank Sensor, EGR Valve and EGR Sensor, Transmission Clutch Solenoid and Clutch transmission fluid pressure switch, Replaced the Ignition Control Module and all three coil packs, new spark plugs and wires, new air filter and fuel filter, Coolant Sensor, Throttle Body, Rebuilt Automatic Transmission. Struts, Shocks, All Vacuum Hoses and Lines, etc.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Re: My 1988 Cadillac Cimarron 2.8L M.P.F.I Car Runs Great. Dies sometimes at stop sig
    I was hoping someone would step up with some ideas but the truth is that we see only 1 or 2 Cimarron owners here a year. Mainly We're mostly Catera owners and since our cars have nothing in common the only help from us would be pure guesswork. My suggestion is to look for forums of cars that use the 2.8L V6, the Fiero forums maybe. I'm sure there are others. Sorry we couldn't be more helpful. Good Luck.
    tj86cimarron is offline Cadillac Owners Fanatic
    Automobile(s): 1986 cimarron 1995 Eldorado ETC
    Sep 2010
    Scranton, PA
    161
    Just saw this post, I am a proud 1986 Cimarron owner - and still drive it!!!! People love it!!!
    Anyway - I know a lot about these cars - as I do all my work myself. And reading these problems I notice that the fuel pressure regulator wasn't changed - it is controlled by a vacuum line which runs/connects from the Throttle Body area after the MAF sensor, to the pressure regulator. You must remove the top of the intake (as you did to change the injectors) to access the fuel pressure regulator. The rubber diaphram in the regulator fails and causes fuel to leak and be sucked into the vaccum hose - which then is injected through the air intake - which floods out the engine -or surges the engine...
    The injectors will test good and work properly.
    If there is no spark present when this failure occurs - does the tach work when you are cranking the engine?
    elvin315 likes this.
