blinker and tranny problems
Results 1 to 4 of 4
Cadillac Catera and Cimarron Forum Discussion, blinker and tranny problems in Past Cadillac Vehicle Discussion; My blinker fuse is blowing about once a day. Thats the first issue. My second one is now my tranny ...
    zigzagcaddy is offline Cadillac Owners Member
    Automobile(s): 1998 catera
    Jul 2014
    33
    12
    My blinker fuse is blowing about once a day. Thats the first issue. My second one is now my tranny seems to shut down when that happens. And before the tranny goes into limp mode the cruise ontrol quits. Help pleaae. Ive only owned my caddy for about a month. I like it. Bit little gremlins keep popping up
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Re: blinker and tranny problems
    *********Kaustein Alert!*****************Kaustein Alert!*******************Kaustein Alert!*******************Kaustein Alert!*******************
    Look at the voltmeter on the dash. It should read a pretty steady 13.5 volts. A little higher after a cold start. I can tell you from experience that the transmission in the Catera is very sensitive to voltage. When the trans starts acting up, it is usually the alternator. Check that battery terminals are clean and tight. Fuses blow either because the voltage is too high (bad alternator) or there is a path to ground, either one causes more current than the fuse is rated at. Since you have two different fuses blowing, the path to ground is the less likely.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    I don't mean to hijack the thread but since we're talking alternators...........
    I have a ScanGauge 2 in my car and when the engine is running it reads between 11.8 - 12.7 volts and rarely breaks 13.0 v. A new Diehard in January made no difference. The battery terminals and cable ends are clean. I had the charging system tested at Advanced Auto Parts and it checked out OK.
    The car has refused to start (dash lights, but no cranking) a few times. A jump start gets her going with no drama on the way back home, but lately every start is a guessing game. Usually it starts but it only takes that one time it doesn't to spoil my day. I suspect the cables but still not convinced it's not the alternator.
    Any ideas before I throw money at the problem?
    Jul 2014
    33
    12
    Voltage reads correct and battery tight. The fog lights are missing and the wire harness is hanging for them. Can that contribute? Ive tied them up. Is there a way to remove just the harness for the for lights?
  7. Remove Advertisements
