Flooding
Results 1 to 6 of 6
Cadillac Catera and Cimarron Forum Discussion, Flooding in Past Cadillac Vehicle Discussion; Hello guys! Today I discovered a flood in my car.... It's not to bad but enough to be worrie and ...
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Hello guys! Today I discovered a flood in my car.... It's not to bad but enough to be worrie and the reason of it because I have no idea how long it's been going on, here in North Carolina we had some heavy rains for a pass week, in and out, so did it happened yesterday or slowly flooded during whole week my front passenger side, I dont know... my carpet and original mat are dark gray and when it's wet u can not really see it. Booth, carpet and mat was soaking wet, lucky me having a steam vacuum cleaner, I just vacuum all that water out, left mat outside overnight to dry and left front windows down, hope it will dry.... now need to find a source of my leak. Any help? Anybody had similar problem before? why my mat is soaking wet if it's have rubber layer underneath? look like water was dripping from the top, not came from the bottom or slowly leaked from the side of the door seal, othere wise mat wouldn't be that wet, maybe a little on the side of it.
    Thank you
    98Catera_2010's Avatar
    98Catera_2010 is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Cadillac Catera Sport
    Oct 2010
    Cookstown, Ontario Canada
    28
    242
    I recently just noticed last week when we had heavy rain a lil puddle of water on my jacket which was on the passenger front seat. I remember reading about sunroof drains getting clogged about a month prior on the forum so I opened my sunroof and sure enough the front corners where the holes are located to drain water had standing water and was not draining. I just need to figure out how to clear them without disconnecting it somewhere along the way.
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: Flooding
    Sunroof drains are probably plugged. I doesn't take much to plug them. If you ope your sunroof, you should be able to see them. Is the headliner stained?
    Zl700's Avatar
    Zl700 is offline Cadillac Owners Fanatic
    Automobile(s): 2014 XTS-Vsport
    Jun 2012
    Houston, TX
    54
    335
    You can try using low pressure air. Too much and you can blow the boot and hose off resulting in needing to drop the headliner some anyways to gain access.
    I some times follow up with a pressurized stream of water to flush hose and the flapper/check valve that is sometimes used at end of hose. (A lot of hose ends or drain ends are not easily accessible)
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Re: Flooding
    There is a drain plug at the bottom of the passenger air cleaner compartment on the right side of the car near the firewall. Take out the filter and you will see that it is clogged with leaves and other debris washed down from the windshield. You can get some of the muck out from the top, but here is a tip. Turn your wheels to the left and look up into the wheel well and you will see the drain plug. You can can clean it out completely that way. When you take out the plug, a ton of muck and water will come out.
    Jul 2008
    712
    Re: Flooding
    Good idea and never thought of that as a problem area. If the headliner wasn't stained, that might be the issue. One of the easy things to replace. But just a reminder you access it from the outside, in the engine area, near the cowl on the passenger side.
  9. Remove Advertisements
