1997 Cadlllac Catera Won't Start after replacing Steering Column
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, 1997 Cadlllac Catera Won't Start after replacing Steering Column in Past Cadillac Vehicle Discussion; Today I replaced the steering column on my 1997 Cadillac Catera. Now it seems as if the car is not ...
    Rev Green is offline Cadillac Owners Member
    Automobile(s): Catera
    Jun 2014
    7
    Now it seems as if the car is not getting fuel and won't start, it just keeps turning over. I was told that there was some reprogramming or decoding process that needs to be done.
    Can anyone please help me out, does a replacement steering column with key need to be encoded or programmed into the system?
    I really need this car for work so if someone can help me out I would be very grateful
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: 1997 Cadlllac Catera Won't Start after replacing Steering Column
    Why did you replace the steering column?
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    why create two same threads?. administration ? where are u ?
    Jul 2008
    712
    Trying to fix his car!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The factory anti theft system disables the starter and fuel pump if the wrong key is detected. Since your engine is cranking, I'd assume that's not the issue. That said, are you using your original lock cylinder and key in the new column?
    Have you pulled the codes?
    Checked fuel pressure?
    Spark?
  8. Remove Advertisements
