car won't crank, but ignition is on
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, car won't crank, but ignition is on in Past Cadillac Vehicle Discussion; Hi all, I'm new to this forum. I have a 99 catera that I purchased. It was running great for ...
    keb
    keb is offline Cadillac Owners Member
    Jul 2014
    Hi all, I'm new to this forum. I have a 99 catera that I purchased. It was running great for a couple of mos, until the other evening when I parked it and the next day it wouldn't even crank. All of the lights were on like I had the key in the ll position, but key just turns. Need a little help. Any suggestions?
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    if it wouldn't even crank its got to be a better. make sure terminals are clean and tight othere then that remove battery and take it to local shop for test or places like Autozone and Advance Auto Part. u can test battery with regular voltmeter but wouldn't be able to test on amp because u will need to put a load on a battery. Store like Harbor Freight in USA sell battery tester for only $20, it always good to have one.
    I had a experience where lady told me that her starter is out cuz its cranking but wouldn't start, and here battery was 1 year old. I test battery with voltmeter just to male sure it have voltage and its showed like 13v , so I replaced starter and its ended up been a battery so u had to remove new starter, return it and install old starter with new battery. .... wish I had that battery load tester that day....
    keb
    Jul 2014
    I had the battery tested and it was good. Seems like it's either the ignition is finished or its not responding to the key correctly, because it stays on same position while I'm turning key....never moves.
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Quote Originally Posted by keb View Post
    here is your answer
    waco-brian's Avatar
    waco-brian is offline Cadillac Owners Fanatic
    Automobile(s): Catera 98 & 99
    Apr 2010
    Waco,Texas
    50
    113
    Re: car won't crank, but ignition is on
    starter switch or key switch. or both .happening to me right now. rock auto sells a key switch with no key or tumblers put my key and tumblers in no need to reprogram for new key.
  8. Remove Advertisements
