1997 Cadillac Catera / Won't Start
Results 1 to 8 of 8
Cadillac Catera and Cimarron Forum Discussion, 1997 Cadillac Catera / Won't Start in Past Cadillac Vehicle Discussion; I 1997 Cadillac Catera Two days ago I replaced the fuel pump, the car was running fine, today the car ...
    Rev Green is offline Cadillac Owners Member
    Automobile(s): Catera
    Jun 2014
    7
    Two days ago I replaced the fuel pump, the car was running fine, today the car will not start I checked the relay number eight replaced it with what I had and the car still seems not to be getting fuel. Although yesterday it was running fine. I was wondering is there some way to bypass the fuel relay, maybe putting a jumper between two ports on the relay base. To activate the fuel pump?
    I just really need some help and I was wondering if someone could help me out. Thank you and God bless
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    how u know that car simply not receiving fuel, u have a gauge ? if u got that lucky u might bought broken part.
    when u try start vehicle is it just crank, ran for second and dies or wouldn't even crank or just cranking but wouldn't run?
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: 1997 Cadillac Catera / Won't Start
    These cars are beyond any help of any supreme being!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    How do you know it's a fuel issue?
    Jun 2014
    7
    The reason that I know it's not getting fuel is because I tested it. After removing the fuel pump relay I used a jumper from the base of the relay the blue and red wires which are directly connected to the fuel pump and put a positive 12 V DC from the battery on it, and the car started. Prior to doing this I simply sprayed some quick start in the intake manifold and the car attempted to start, shortly after dying again.
    Thanks for your inquiry I appreciate the help, Rev.
    Sep 2010
    East Boston MA.
    29
    26,325
    The pump will only run for a couple seconds at key on to prime, and not again until cranking. It isn't doing that?
    makeitsnappy is offline Cadillac Owners Member
    Automobile(s): 91 deville,98 catera
    Jun 2014
    east texas
    23
    that's really peculiar, you might try using a spare key if you have one. all it takes is a little scratch on these keys and it will crank but wont start. This happened to me after I mistakenly place my key in a 03' ford focus ignition, the kicker was the key had been cut and programed less than three before and it was only two indentations on ether side at the point. you would have to use a magnifier to see it. Just a thought it could be something different altogether. I know when I replaced my fuel pump I had to replace all the wires and float because they had completely disintegrated.
    marko69 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera Sport, 1990 Porsche 944 S2 cab
    Jun 2011
    Tampa
    109
    Quote Originally Posted by Rev Green View Post
    From the schematic, you should be able to bypass relay K44 (for troubleshooting) by jumpering pins 2 + 8 of the relay socket.
  11. Remove Advertisements
