help please (vacuum lines)
Results 1 to 8 of 8
Cadillac Catera and Cimarron Forum Discussion, help please (vacuum lines) in Past Cadillac Vehicle Discussion; 99 catera 136k runs like new first off, i'm not a mechanic nor do I know a whole lot about ...
    dstacy90 is offline Cadillac Owners Member
    Automobile(s): 99 catera
    Mar 2014
    26
    5
    99 catera
    136k
    runs like new
    first off, i'm not a mechanic nor do I know a whole lot about cars. but i'm learning. my question has to do with the vacuum lines. I opened the hood to find a line disconnected from a source, and I have NO IDEA where it goes. I've researched everything I could think of.
    the car doesn't run any worse without it, but I need to know where to place it. i hope these pictures help
    all help would be appreciated
    Mar 2014
    26
    5
    Re: help please (vacuum lines)
    heres a different pic
    Mar 2014
    26
    5
    nevermind... the piece that it connected to broke off somehow. but issue resolved... can somebody tell me where I could buy that hose that connects to the right side of the manifold?
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    U should to fine hoses like that in autozone, advanced auto parts
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    What hose to what manifold?
    If its a vacuum hose, any size vacuum hose is available by the foot or in bulk at any parts store. And any plastic vacuum line can be replaced with vacuum hose.
    marko69 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera Sport, 1990 Porsche 944 S2 cab
    Jun 2011
    Tampa
    109
    I had a terrible time trying to replace that vacuum line/brake check valve setup. It's a hard line that has sharp curves. New check valve, new fittings, but I couldn't get a hose line to make the sharp curves without it collapsing on the bends. Maybe I was using the wrong type of hose. In the end, I finally found a catera at the junk yard that didn't have a broken check valve stem.
    Whatever you replace it with, make sure the large hose doesn't rest on the a/c line.
    Sep 2010
    East Boston MA.
    29
    26,325
    You can use hose and 45/90 fittings to make sharp bends.
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Also u can buy all kind of L shape or U shape houses at the same place - auto zone, advance auto, car quest, napa and o'riley, just shop around or give them a call
  11. Remove Advertisements
