need some help
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Cadillac Catera and Cimarron Forum Discussion, need some help in Past Cadillac Vehicle Discussion; 2001 catera hey everyone I just replaced all 4 O2 Sensor yesterday now im getting codes p1141 p1161 p0141 p0161 ...
    darksky47 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2008
    46
    need some help
    2001 catera
    p1141 p1161 p0141 p0161 P0300, P0302, P0304, P0306 I cleared the codes
    everyone came back but P0300, P0302, P0304, P0306 they stayed off could I have got two bad O2 Sensor.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Quote Originally Posted by darksky47 View Post
    2001 catera
    No. Its all miss fire. P0300 - multiple miss fire, p0302, 04 and 06 its miss fire on cylinders 2, 4 and 6
    Mar 2008
    46
    Re: need some help
    would that cause the O2 Sensor p1141 p1161 p0141 p0161 light to come on
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    So u replaced all 4 O2 sensors ONLY? U didnt touch anything?
    And
    Did u used OEM New O2 sensors or universal?
    Mar 2008
    46
    Re: need some help
    bosch 02 sensor is all I used on all four not universal I did not do anything else to it.
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Cylinders 2,4,6 located on driver side. Check contention on O2 wires, if im not mistaken I had simular problem due to bad connection, just spray some ececrtic connection cleaner on harness and then plug it back.
    And what was the reason for u to replace all O2 sensors. Did u got error codes on them?. I replaced only 2 that before catalyst, after catalyst still original with 165k on them
    Thats what I found on my AllData.com
    IMPORTANT: The harness must not contact any of the hot exhaust components. The rear Heated Oxygen Sensor (HO2S) pigtail has white tape at the intervals, indicating the proper location of each retaining clip. When connecting the sensor pigtail to the harness ensure that the connector seal is crushed uniformly all the way around between the connectors.
    OEM part # for O2 sensors:
    Before catalyst: 9198809
    After catalyst: 9120293
    Mar 2008
    46
    Re: need some help
    I changed them for two reasons 180,000 miles and I was I was getting code P0411
    I have done everything I could think of even took it to the shop had a smoke test, checked the
    air pump running find replaced the Air Bypass Valve, replaced Air Pump Check Valve, Air Bypass Valve ,
    and the intake Manifold Tuning Valve still p0411 last thing was I replaced the 02 sensors well the p0411 is
    gone but the codes p01141 p01161 p0141 p0161 replaced it. My car I love it and hate it at the same time.
    if you like I can post what my scanner says it has all the real time data.
    Mar 2008
    46
    Re: need some help
    Ok I replaced the coil packs that code is gone. I I cleaned the 02 sensors with ececrtic cleaner but I don't know how to do Check contention of wires. Could there be a fuse or something.thanks
    2001 Cadillac Catera R = 3.0
    I/M Monitors
    Since DTCs Cleared
    Misfire Monitor ok
    Fuel System Mon ok
    Comp Component ok
    Catalyst Mon inc
    Htd Catalyst n/a
    Evap System Mon ok
    Sec Air System inc
    A/C Refrig Mon n/a
    Oxygen Sens Mon inc
    Oxygen Sens Htr ok
    EGR/VVT Sys Mon n/a
    DTCs (Codes)
    P1141 ENG $11
    Heated Oxygen Sensor Heater Control
    Circuit Bank 1 Sensor 2
    P1161 ENG $11
    Circuit Bank 2 Sensor 2
    P0141 ENG $11
    Oxygen Sensor Heater Circuit Bank 1
    Sensor 2
    P0161 ENG $11
    Oxygen Sensor Heater Circuit Bank 2
    Sensor 2
    P0140 ENG $11
    Oxygen Sensor Circuit No Activity
    Detected Bank 1 Sensor 2
    P0160 ENG $11
    Detected Bank 2 Sensor 2
    State OBD Check
    MIL Status ON
    Codes Found 4
    Monitors OK 7
    Monitors Inc 1
    Monitors N/A 3
    View Freeze Data
    No freeze frame stored -- freeze frame
    event not detected
    O2 Monitor Tests
    O2 Bank1 Sensor1
    Test $81
    MOD $11
    MAX 255
    MEAS 128
    MIN 90
    Test $82
    MOD $11
    MAX 255
    MEAS 128
    MIN 90
    Test $83
    MOD $11
    MAX 205
    MEAS 103
    MIN 31
    Test $84
    MOD $11
    MAX 205
    MEAS 127
    MIN 51
    O2 Bank1 Sensor2
    RICH-LN Thresh
    MOD $11
    MAX -----(V)
    MEAS 0.575(V)
    MIN -----(V)
    LN-RICH Thresh
    MOD $11
    MAX -----(V)
    MEAS 0.575(V)
    MIN -----(V)
    Min V for Cycle
    MOD $11
    MAX 0.385(V)
    MEAS 0.190(V)
    MIN 0.000(V)
    Max V for Cycle
    MOD $11
    MAX 1.010(V)
    MEAS 0.720(V)
    MIN 0.480(V)
    O2 Bank2 Sensor1
    Test $81
    MOD $11
    MAX 255
    MEAS 129
    MIN 90
    Test $82
    MOD $11
    MAX 255
    MEAS 128
    MIN 90
    Test $83
    MOD $11
    MAX 205
    MEAS 106
    MIN 31
    Test $84
    MOD $11
    MAX 205
    MEAS 125
    MIN 51
    O2 Bank2 Sensor2
    RICH-LN Thresh
    MOD $11
    MAX -----(V)
    MEAS 0.575(V)
    MIN -----(V)
    LN-RICH Thresh
    MOD $11
    MAX -----(V)
    MEAS 0.575(V)
    MIN -----(V)
    Min V for Cycle
    MOD $11
    MAX 0.385(V)
    MEAS 0.190(V)
    MIN 0.000(V)
    Max V for Cycle
    MOD $11
    MAX 1.010(V)
    MEAS 0.720(V)
    MIN 0.480(V)
    Diag Monitor Tests
    Test $01
    ID 00
    MOD $11
    MAX 00
    MEAS 00
    MIN ----
    STS OK
    Test $03
    ID 01
    MOD $11
    MAX ----
    MEAS 8E
    MIN 5B
    STS OK
    ID 00
    MOD $11
    MAX 00
    MEAS 00
    MIN ----
    STS OK
    ID 01
    MOD $11
    MAX ----
    MEAS A0
    MIN 5B
    STS OK
    ID 00
    MOD $11
    MAX 00
    MEAS 00
    MIN ----
    STS OK
    Test $05
    ID 00
    MOD $11
    MAX 00
    MEAS 00
    MIN ----
    STS OK
    Modules Present
    Module $18: ISO
    Module $11: ISO
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Thats really weird... all o2 sensors u replaced not connecting... I dont think its a fuse, but its always good to check! Pull every single fuse and check it. It was a tread here on forum where guy had all o2 sensors codes and by replacing secondary air injection pump fixed all that
    marko69 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera Sport, 1990 Porsche 944 S2 cab
    Jun 2011
    Tampa
    109
    Re: need some help
    Might want to check fuse 43 in the ECM housing.
    Looks like you have 4 out 6 of these codes for the heated o2 control circuit.
    From the manual:
    Using the scan tool, observe the DTC information.
    Are DTCs P0135, P0141, P0155, P0161, P1141 or P1161 set?
    Yes, Go to Step 3
    3
    Turn OFF the ignition.
    Inspect fuse 43 for the oxygen sensor heaters located in the ECM housing.
    Is fuse 43 open?
    Mar 2008
    46
    Re: need some help
    I have looked but my ECM house does not look like the oweners manual where #43 fuse is in the picture I don't have it here is a picture of my ECM
    Jun 2011
    Tampa
    109
    Re: need some help
    It's probably that little green one on the far left. It's supposed to be a 30 amp fuse and that's what that one is. The component locator shows #43 above that orange relay and it doesn't show the little green one, so that's probably it. It wouldn't be the first time my manual shows a component in the wrong place. It showed relay k134 in the wrong location also.
    (1) Additional Harness
    (2) Fuse #40 (30A)
    (3) Fuse #52 (30A)
    (4) ECM Ground
    (5) Connector C110
    (6) Coolant Fan Test Connector
    (7) ECM Module
    (8) ECM Connector C1
    (9) A Fuse #42 (40A) B Fuse #49 (50A)
    (10) Fan Control Relay (Orange)
    (11) Fuel Pump Relay (Violet)
    (12) P108
    (13) Additional Harness to Battery
    (14) Instrument Panel Wiring Harness
    (15) P104
    (16) I/P Harness
    (17) Fuse #43
    (18) Engine Controls Power Relay (Violet)
    (19) Fan Control Relay (Brown)
    (20) Fuse #50 (For Fan Control & W/W Motor Relays)
    (21) Fan Control Relay (Gray)
    (22) Fan Control Relay (Green)
    (23) A/C Compressor Relay (Green)
    (24) Windshield Wiper Motor Relay (Yellow)
    (25) Auxiliary Water Pump Relay (White)
    (26) Fan Control Relay (Blue)
    (27) Secondary Air Injection Pump Relay (Brown)
    Mar 2008
    46
    Re: need some help
    well that 30 amp on the far left is good
  16. #14
    Jun 2011
    Tampa
    109
    Re: need some help
    Have you tried reconnecting the old sensors?
  17. #15
    Mar 2008
    46
    Re: need some help
    I got a friend that can get a snap on scanner from a dealer ship where he works he is going to bring it home today I will kep you updated with what he finds.
  18. Remove Advertisements
