transmission shifter and steering wheel vibrates....
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, transmission shifter and steering wheel vibrates.... in Past Cadillac Vehicle Discussion; It has always done this but i replaced both sides of the cars tie rod ends and replaced rotors and ...
    coldsteel82 is offline Cadillac Owners Member
    Automobile(s): carera
    Oct 2013
    34
    13
    It has always done this but i replaced both sides of the cars tie rod ends and replaced rotors and brake pads but the transmission shift knob will shake bad and the steering will just a little. O yeah also replaced the shocks. I was thinking the lower control arms becuase when i had it pulled apart I could see shiny ball part of the bushing, dont know if that is suppose to be like that or if all you should see is bushing but the reason i ask is becuase if its something else and i end up replacing the lower control arms then im going to be
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    I had exact same thing!!! After I replaced my control arms - no more vibration!!!
    thats strange
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Re: transmission shifter and steering wheel vibrates....
    Quote Originally Posted by coldsteel82 View Post
    Does the car shake constantly or just when braking? The control arm bushings will cause the shakes under braking. If you see the metal innards of the rear/vertical bushing it is definitely shot. You'll also see leaked silicon fluid from that bushing when it splits open. The front/horizontals don't have the same ball pivots as the rear/vert but they also tear, just not as easy to spot. My Sport had the braking shakes and I replaced all 4 bushings. Problem solved!
    Read my suspension thread and learn more.
    http://cateraowners.forumotion.com/t...pgrades-part-1
    Might as well read the other stuff regarding the Catera like the timing belt & tensioner, oil cooler, heater bypass valve, GTO brakes, etc.
    The shifter shaking might be related to the bushings but maybe not. I'd guess broken motor or transmission mounts but since the shifter isn't connected directly to the tranny (except by its linkage) I kind of doubt it could be them but I've been wrong before. I had the transmission replaced and a couple of linkage bolts loosened which caused a lot of play/slop at the shifter making it hard to put it into PARK. Is that a problem you've noticed?
