Oil Cooler - 1997 Catera
Results 1 to 6 of 6
Cadillac Catera and Cimarron Forum Discussion, Oil Cooler - 1997 Catera in Past Cadillac Vehicle Discussion; I just recently purchased a 97 Cadillac catera and the oil cooler for the engine that's located under the intake ...
    tlbressie is offline Cadillac Owners Member
    Automobile(s): 1997 Cadillac Catera
    Mar 2014
    1
    I just recently purchased a 97 Cadillac catera and the oil cooler for the engine that's located under the intake was not there. Is it a necessary thing to have it if I will be driving it regularly or can I manage without it until I can purchase one.
    Sent from AutoGuide.com Free App
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Re: Oil Cooler - 1997 Catera
    Are you aware that the oil cooler is located inside the engine block?
    Fifty9cadillac is offline Cadillac Owners Member
    Automobile(s): 1959
    Mar 2014
    36
    The oil cooler could also be apart of our radiator if they didn't discontinue it that year!?
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Quote Originally Posted by Fifty9cadillac View Post
    No, not really. The engine oil cooler lives in the block, under the cover plate between the heads. There's a coolant gallery under there. Notice the oil lines on that plate. It's prone to leaking if the coolant PH leans toward acidic. If it leaks coolant leaks into the oil system, showing as a creamy goo in the coolant reservoir and dipstick. You might see the same residue under the oil filler cap but that may just be condensation that burns off after the engine heats up. Regularly changing the coolant is the best way to prevent this leaking from happening. The oil cooler on the radiator is for the transmission but only on the '99-'01 Cateras if I remember correctly.
    Number 18 in the diagram below are the oil cooler and its associated parts. Numbers 1 & 2 are its oil lines.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Number 18 in the diagram below are the oil cooler and its associated parts. Numbers 1 & 2 are the oil lines.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    i have all video recorder how to replace oil cooler, hope will find time to edit
  9. Remove Advertisements
