97 Catera doesnt downshift to 1st gear at stop.
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, 97 Catera doesnt downshift to 1st gear at stop. in Past Cadillac Vehicle Discussion; Car has just turned 94k miles. You have to manually shift to low in order to start from a stop ...
    racecar785 is offline Cadillac Owners Member
    Automobile(s): 97 catera
    Mar 2014
    63
    Car has just turned 94k miles. You have to manually shift to low in order to start from a stop sign. the upshift feels like it is jumping from 1st gear to 3rd. but shift quality is okay, there is no slipping. You come to a stop and u must manally shift downt to ffirst or it feels as if it want to take off in like 3rd gear.
    Does this seem like an internal transmission issue or the control module?
    the problem came on all at once. Trans was serviced just last year and all looked fine.
    My climate control all of a sudden stopped , it worked one day and not the next. No
    lights on climate control or no sign of any power..
    Has anyone run into this situation before?
    THANK YOU !
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: 97 Catera doesnt downshift to 1st gear at stop.
    Did you just get the car? If so, read through the posts here
    Buster28 is offline Cadillac Owners Member
    Automobile(s): 2000 ETC 18K miles, 1991 Allante 11K miles, 1996 ETC (sold)
    Sep 2010
    RI
    23
    There are 2 shift solenoid valves, the 1-2/3-4 (Shift A) and the 2-3 (Shift B). To select Drive 1st gear the transmission "computer" energizes the Shift B solenoid. To upshift into 2nd the Shift A solenoid is energized, so both are energized. L range (Manual 1st) selects 1st gear with out using the Shift B solenoid, therefore, when the Shift B solenoid won't energize it feels like a 1st to 3rd shift because the shift B solenoid needs to be energized in 2nd. You symptom strongly suggests you have a defective shift B solenoid. A new one costs about 35 bucks, replacement requires removal of the large pan and filter. It is a messy DIY job and takes a couple of hours.
