1998 Catera Codes 0161, 0141, 0411, 0140, 0455,
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, 1998 Catera Codes 0161, 0141, 0411, 0140, 0455, in Past Cadillac Vehicle Discussion; Took my Cat to Autozone and got these codes. Seems like a lot. Anybody have experience with these codes and ...
    leslielarsen is offline Cadillac Owners Member
    Automobile(s): 1998 Catera
    Feb 2014
    Took my Cat to Autozone and got these codes. Seems like a lot. Anybody have experience with these codes and suggestions on where to start. Thanks!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Codes are meaningless without definitions, and those aren't even cpmete codes. What are the letters on front of them? P? C? B? U?
    w98seeng is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville
    Mar 2011
    54
    114
    Re: 1998 Catera Codes 0161, 0141, 0411, 0140, 0455,
    P0161 - Oxygen O2 Sensor Circuit Low Voltage (Bank 2, Sensor 2)
    http://www.obd-codes.com/p0161
    P0141 - O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
    http://www.obd-codes.com/p0141
    P0411 - Secondary Air Injection System Incorrect Flow Detected
    http://www.obd-codes.com/p0411
    P0140 - 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
    http://www.obd-codes.com/p0140
    P0455 - Evaporative Emission Control System Leak Detected (no purge flow or large leak)
    http://www.obd-codes.com/p0455
    Ian
    Feb 2014
    Quote Originally Posted by w98seeng View Post
    Ian
    Yep those are the definitions on the print out. Now does anyone have a suggestion on where I should start with this? Seems like some of these codes are related so possibly fixing one thing will eliminate more than one code. Just a guess though. Obviously I have no experience with this kind of thing. :-)
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Secondary air injection pump pressurized your engine every time you start the vehicle and during it's running. If your start your vehicle and it sounds like loud vacuum cleaner working at the same time for few minutes, it's mean your pump open and pumping air not in engine and you have to reseal your pump, if its sounds like vacuum cleaner running but its not loud for a minute or 2, its mean pump working correctly, but check your hoses if they off or broken, if you do not hear any noise you need to check your fuses, check if any voltage going to pump too, otherwise you will need to replace pump. Thread was here on forum not to long ago about same symptoms when air pump went out and guy had all o2 sensors codes
    Search for threads!!!!
    Of O2 sensors and air pump, read all of them, u can find and solved your issue
  8. Remove Advertisements
