Code P0501
Results 1 to 4 of 4
Cadillac Catera and Cimarron Forum Discussion, Code P0501 in Past Cadillac Vehicle Discussion; I'm getting code P0501 which is "Speed Sensor A/Range, Pergormance". Where is that located?...
    Al Leverick is offline Cadillac Owners Member
    Oct 2004
    27
    Code P0501
    Vesicant's Avatar
    Vesicant is offline Cadillac Owners Connoisseur
    Automobile(s): None :(
    Nov 2003
    Jacksonville, FL
    2,703
    Re: Code P0501
    P0501 - Vehicle Speed Sensor Range/Performance
    On the back of the transmission, that one I believe is on the output shaft.
    Is your speedometer still working? The speed correct? Go to an autozone and get the codes erased then see if it comes back.
    #17 on this photo. I hope theres just one sensor.
    Oct 2004
    27
    Re: Code P0501
    No, speedometer does not work when TC/ABS warning lights are lit. They go on an off from time to time.
    Enz
    Enz is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jul 2007
    25
    Re: Code P0501
    Yes this happened to my 1998 catera as well; fixed it myself:
    put the front-tires up on ramps, turn car off & lock emergency brake
    crawl approx. middle of the car- you'll see the drive column
    locate a deppressed area and look for a black wire attached to a sensor perched above the drive column- I think its a 10mm bolt head. Unloosen bolt-head and replace sensor. Start car- the speedo-neddle will return to normal.
    Sontov
  7. Remove Advertisements
