To Remove:
Remove the wiper arms.
Remove the left and the right side air inlet grilles.
Remove the wiper motor.
Remove the power brake booster vacuum connection from intake plenum.
Remove the
spark plug wiring harness from ignition coil.
Remove the electrical connection from ignition coil.
Remove the bolts from the ignition coil.
Remove the ignition coil.
And then to Re-Install:
Install the ignition coil.
Install the bolts to ignition coil.
NOTE: Refer to Fastener Notice in Cautions and Notices.
Tighten Tighten the ignition coil bolts to
8 N.m (71 lb in) .
Install the electrical connection to ignition coil.
Install the
spark plug wiring harness to ignition coil.
Install the power brake booster vacuum connection to intake plenum.
Tighten Tighten the power brake booster vacuum connection until snug. Counter hold fitting while tightening.
Install the wiper motor.
Install the left and the right side air inlet grilles.
Install the wiper arms.
See attached pictures.....
I hope this helps. Nothing like removing things you can't see!! Gotta love the Catera!!!!!!!
