Car starts for a second then dies
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Cadillac Catera and Cimarron Forum Discussion, Car starts for a second then dies in Past Cadillac Vehicle Discussion; Hi i am new to this forum after looking all over the internet for a solution couldnt really find a ...
    shawnTv6 is offline Cadillac Owners Member
    Feb 2014
    5
    Hi i am new to this forum after looking all over the internet for a solution couldnt really find a strait answer for my Catera. It all started one day when i was dropping my little sister off at school, it was running good all the way to the school i walked my sister to her class came back to start it and it would not start right away. I then knew it would be a problem becuase it would usually start up the third time, it took me 15 tries to start it i then left and went strait home i then shut off the car again and tried to start it to see if it would start and it wouldnt. I then disconnected the battery to see if it would reset i hooked it back up about 30 min later and tried again but it wouldnt start for me, all it did was crank not even fire up.I then realized that before the check engine light would come on and it never came on again, soon after trying and trying the TC light stayed on and i couldnt turn it off like before. So after that i checked for codes and it gave me nothing i then started replacing parts starting with the crankshaft position sensor ,it still wouldnt start, i then changed the spark plugs(has spark), coil pack,the mass airflow sensor,checked the fuel pump(its ok has pressure),changed the fuel filter,checked all vacum lines,timing was ok so i bought a used ECU it then fired up but then died right away. also the TC light now turns off and i can turn off/on the TC. would the ECU be the problem and if i get it reprogamed to the cars VIN will it start? just wanna know before i spend cash for a tow and to reprogram it? Any help would be very apprieciated. my car hasnt started in over 2 months and i miss it alot.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    When u say it wouldn't start u mean its just cranking or it starts and dies right away ???
    If it stars and dies, watch my youtube video
    https://www.youtube.com/watch?v=Ds3k...e_gdata_player
    If it just cranks u need to replace crankshaft position sensor. I did same on mine and its work just fine.
    Last thing would be to tow to the dealer, u can get tow money back from insurance,
    They can do full diagnostic for $125. They will tell u what's wrong with and then u can take it home and fix it your self.
    I did same thing with my speedometer problem, the diagnose that my instrumental cluster need to be replace, I did it at home and saved $800
    Feb 2014
    5
    thanks for the reply johnjjo I have changed the CPS and and changed the battery terminals still nothing.. I really think it is the ECU but I will take in to the dealership for diagnostic. Thanks for the advice I appreciate it
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Quote Originally Posted by shawnTv6 View Post
    Did u replaced crankshaft position sensor that next to oil filter ?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    He has stated twice already that he's replaced the CKP,s.
    Throwing parts at the problem is not the way to go.
    What was the fuel pressure?
    Feb 2014
    5
    Thanks for responding I had about 50 psi when I checked the pressure
    Sep 2010
    East Boston MA.
    29
    26,325
    And you have no codes now, current or history?
    Will it run if you hold the throttle open just a little?
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: Car starts for a second then dies
    Please let others know how you make out at the dealer. I've had dealers give me prices so high, not because that is the cost, it is because they don't want to work on the Catera. Talked with the owner of Valley Cadillac in Rochester, NY. That was her answer.
    Feb 2014
    5
    The first ECU I had in the car no codes showed. when I put the new(used) ECU in I got back a MAF sensor and a transmission solenoid. the car was running excellent before,no problems besides the radiator that I changed because it was leaking a year ago
    I will let u know kaustein so far the dealer ship told me it will be $120 to reprogram the ECU and $130 for a diagnostic
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Sorry. My bad thought he replaced camshaft position sensor not crank.
    Feb 2014
    5
    CATERA IS WORKING!!! just needed to reprogram the ECU now car runs fine after all the headache it was all worth the $150 to get it started l. thanks for all the help everyone that replied
    Jul 2008
    712
    Read the post here so you can become informed of any other possible issues.
    Caddy sac's Avatar
    Caddy sac is offline Cadillac Owners Member
    Automobile(s): 2000 catera
    Feb 2014
    1
    What's up? I have a 2000 catera I was having a similar problem all my dash warning lights was on, I kept having to jump start it then I realized that my battery was not holding a charge. My translation wasn't shifting right so I went to junkyard and pulled out 2 tcm's ( transmission control modules). Installed it and still the samething, the abs, tc and check engine lights came back. I unplugged battery for a while replugged it still the samething plus a jumpstart. I bought a new battery. So I check my charging system I took the neg cable off and and car engine died. So my next step was to put a new altenator. And guess what it worked. In conclusion the catera will act up if it doesn't get the right voltage to operate. The catera is a computer driving car.
  16. #14
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    How is Duralast remanufactur altinators guys, I probably will replace it, its $151 on rock auto acdelco reman. for $180. Look like to me its same thing, autozone just rebarnd it to duralast
  17. #15
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    My car wouldn't start sometime, when I try to crank all just dies, no crank at all. Dies like no battery up there, only hearing clicking noise of relay somewhere under steering wheel. For me to start car again I have to disconnected position wire on the battery just for a second, then just put it car and car Starts right away!!!!! Help
  18. Remove Advertisements
