2000 aters Positive battery cable
Results 1 to 7 of 7
Cadillac Catera and Cimarron Forum Discussion, 2000 aters Positive battery cable in Past Cadillac Vehicle Discussion; Is there anywhere that sells the positive battery cable? I ordered one on e-bay and it is just a standard ...
    2000GoldCatera is offline Cadillac Owners Member
    Automobile(s): 2000 Catera
    Nov 2013
    55
    17
    Is there anywhere that sells the positive battery cable? I ordered one on e-bay and it is just a standard cable. I have the alternator out and since reading on this forum while I have it apart might as well change the cable too. If I cant find any I guess I will just put the new alt. in and see how it goes.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    What kind of problems u have that u do all that ???
    Nov 2013
    55
    17
    Re: 2000 aters Positive battery cable
    The alternator was only putting out 11 volts. I have read on this forum that the positive cable can cause the same problem. So while I have it all apart I thought I would do both at the same time. I just can't find one anywhere.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Here's a tutorial on making your own Battery cables:
    http://www.pbase.com/mainecruising/battery_cables
    Nov 2013
    55
    17
    Just an update, alternator changed and that problem has been fixed. Now I am changing the crankshaft position switch!
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Did you finally replace the positive cable? The ground?
    Nov 2013
    55
    17
    QuestionRe: 2000 aters Positive battery cable
    No tyet, work and weather has kept me busy, everything seams to work good with the exception of when I use the rear defrost it fraws a bunch of power and since I am not an electrician I am trying to figure out the proper gauge of wire eithe 2 or 4.
  10. Remove Advertisements
