97 catera vibrates during acceleration!!
Results 1 to 11 of 11
Cadillac Catera and Cimarron Forum Discussion, 97 catera vibrates during acceleration!! in Past Cadillac Vehicle Discussion; I was headed to the store an leaving my parking lot I hit ice an slid side ways a bit ...
    josh42088 is offline Cadillac Owners Member
    Automobile(s): 97 catera
    Jan 2014
    31
    Unhappy97 catera vibrates during acceleration!!
    I was headed to the store an leaving my parking lot I hit ice an slid side ways a bit then hit dry pavement while still a bit side ways wasn't going fast at all drove on like 5 miles with no problems when I got back in an pulled out it vibrated a bit when I took off didn't think to much of it went through the gears fine I got up to 50 an maintained for a mile or so then went to acc on up to 55 an I vibrated almost like hitting drunk bumps but onnly if i tried to acc nothing while just maintaining speed what's up!!!!! 99 059 miles had it a year with no major problems could use an oil change an other regular maintenance but nothing drastic please help!
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: 97 catera vibrates during acceleration!!
    I'd guess your sideways travel put stress on some suspension part and messed something up.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Suspension components shouldn't cause vibration like that while accelerating.
    Do you feel it through the steering wheel or whole car? Is the check engine light on or flashing? It almost sounds like a misfire.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Thats sucks, u need to do alignment now, also let them check tires balance, u might slightly bend your rimp.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Which end slid out? Front or rear? Which side? Left or right? I'd jack up one corner at a time and spin the tires to check if maybe one got unseated from its wheel. All look OK? Then it might be a wheel tossed a weight. They're usually on the inner sidewall and not obvious to spot. You'll have to have the tire rebalanced if that's the case. If none of that fixes the problem then you'll have to pay someone to check for damaged components but since it happens at a set speed I think it's probably a spinning mass that's at fault. Very unlikely but possible, it could be a bent rear axle or damaged constant velocity (CV) joint.
    Sep 2010
    East Boston MA.
    29
    26,325
    No difference between what the OP did and throwing the car into a hard corner. He slid onto dry pavement, not a curb or a ditch. It did not affect tire balance (and that would vibrate at all times, not just while accelerating). It did not affect alignment (the tire breaks traction LONG before any steering/suspension components are damaged), and alignment has nothing to do with a vibration. If a tire was "unseated" from a rim, it would be flat. There certainly is no rim damage (and again, that would cause vibration all the time).
    Note that the OP drove 5 miles after it happened with no problem. It started the next time he drove the car:
    Quote Originally Posted by josh42088
    The issue is in all likelihood completely unrelated.
    BTW, Josh, didn't notice you were a new member.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Hey, I was just working from what he provided. You have to start somewhere. As far as the tire unseating, it happened to me with a Volkswagen. Hit a pothole and the tire shifted its bead. Not completely and not enough to go flat right away but it did shimmy the car at speed. Same Volkswagen, different day, (1971 Squareback) I slid on an icy traffic circle, hit a curb, and bent the lower front trailing arm. Drove it from Flushing Meadows Park to The Bronx like that, tire/wheel tucked under and the car pulling to the left all the way home. No shaking, just pulling. Still say it's a rotating mass. Probably tire/wheel. Maybe even a wheel bearing.
    Sep 2010
    East Boston MA.
    29
    26,325
    I would say rotating mass as well, except it's only vibrating whole accelerating.
    Need feedback from the OP as to what's vibrating. And maybe there's more to the story.
    Jul 2008
    712
    Tie rod, engine mount.
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Quote Originally Posted by kaustein View Post
    Engine mount would be my theory. Vibrates when torque is appied during acceleration
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    You guys gave me an idea. Forget the wheels, it could be the transmission mount. It's mostly a rubber pad and I needed mine replaced when the tranny work was done. Everything in the tranny rotates, including the drive shaft, and it fits the "under acceleration" part.
  14. Remove Advertisements
