cadillac catera codes
Results 1 to 13 of 13
Like Tree1Likes
  • 2 Post By jeepzrcool
Cadillac Catera and Cimarron Forum Discussion, cadillac catera codes in Past Cadillac Vehicle Discussion; I wonder if someone can help me. I have been having a problem with loss of power in my 1997 ...
    jeepzrcool is offline Cadillac Owners Member
    Jun 2005
    Old Forge, Pa
    56
    4
    Questioncadillac catera codes
    I wonder if someone can help me. I have been having a problem with loss of power in my 1997 cadillac catera. I had the dealer check the codes and it cmae up PO300, PO302, PO305. They say that numer 2 and 5 cylinders are not firing properly and that both of the catalytic conertors is blocked because it needed a tuneup. They wanted to tune it up and replace the convertors at a price of over $3500.00. I spoke with a mechanic (not cadillac dealers) and he said that I may not need the convertors replaced they may clear once I tune the car up, he said they also might not but that it is a very expensive to do so and just to do the tuneup first.
    What exactly do the codes that I have listed mean. The dealer is very reluctant to give you the exact meaning of them if you do not intend to get the car serviced at their dealership.
    Vesicant's Avatar
    Vesicant is offline Cadillac Owners Connoisseur
    Automobile(s): None :(
    Nov 2003
    Jacksonville, FL
    2,703
    Re: cadillac catera codes
    All those codes mean:
    DTC P0300 - Engine Misfire Detected
    DTC P0302 - Cylinder 2 Misfire Detected
    DTC P0305 - Cylinder 5 Misfire Detected
    Im a bit confused... If the catalytic converters are indeed clogged, doing a tuneup will not fix the converters; they need to be replaced.
    Otherwise for the misfiring, the two cylinders that are misfiring; since they are both run from the same coil pack, im going to guess that the coil pack might have gone bad. When they do a tuneup tell them to test it. The pack for cylinders 5 & 2.
    http://autorepair.about.com/library/...bl-fo-5133.htm
    While you're at it, you could also check for oil intrusion in the plug boot or sparkplug (take out the sparkplug boot and see if theres oil inthere).
    Jun 2005
    Old Forge, Pa
    56
    4
    Yes there is opil in the spark plug boot, they also said I have to have the Valve convers changed.
    Vesicant's Avatar
    Nov 2003
    Jacksonville, FL
    2,703
    Quote Originally Posted by jeepzrcool
    Ahh then that'd probably be the reason for the misfiring.
    Jun 2005
    Old Forge, Pa
    56
    4
    so if i replace the valve cover gaskets and give it a tuneup, should it be okay?
    Vesicant's Avatar
    Nov 2003
    Jacksonville, FL
    2,703
    Yeah.
    But what about the catalytic converters? Are those actually clogged... thats the next question. Dealer may have been messing with you there. The car should have set a code for that.
    AllenPacla is offline Cadillac Owners Fanatic
    Nov 2004
    New York
    447
    It's sensible to go for the valve cover gaskets first and then a tune up. Don't go for the catalytic converters replacement yet because i for one don't see the point. I was told once by a so-so mechanic that i need to replace my oxygen sensors and the Mass Airflow sensor when i should only replace the MAF and not the oxygen sensors. Just like Jeff said, the dealer or whoever he is , is messing with you. With the Catera, you have to take it one a time. Fix the first and foremost problem first and then go from there. And just like Jeff said, there should be a code for the Catalytic converters if they are really bad.
    Jun 2005
    Old Forge, Pa
    56
    4
    Thank you for all of your help everyone. It is greatly appreciated
    Mariosierra and Mariosierra like this.
    Mariosierra's Avatar
    Mariosierra is offline Cadillac Owners Member
    Automobile(s): 98 Catera
    Oct 2011
    Casa Grande, Arizona, United S
    33
    3
    Having bad valve cover gaskets causes to misfire right ?
    Oct 2011
    33
    3
    i have a 98 cadillac catera check engine is on i put the code reader machine and it cave me B0241 can anyone help me with this code .. :/
    hemic05 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS 1SG 2001 Cadillac Catera Sport
    Sep 2011
    Plainfield ILL
    59
    139
    Do the valve covers not just the gaskets on the cateras they are injected plastic and with age warp as the whole car does then do your tune up on these its just plugs so its not a great cost hell just pull the coil packs and the plugs are there do it yourself
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by Mariosierra View Post
    No, oil is dielectric (an electrical insulator). Even with the plug well completely full of oil, the path of least resistance is still through the plugs center electrode, to the ground electrode. The plug would still fire. The coil pack is the most likely culprit, given the cylinders that are misfiring. Carbon tracked plug boots are also a possibility. How many miles on this Cat?
    waco-brian's Avatar
    waco-brian is offline Cadillac Owners Fanatic
    Automobile(s): Catera 98 & 99
    Apr 2010
    Waco,Texas
    50
    113
    Quote Originally Posted by jeepzrcool View Post
    had the same codes on my 99 last year turns out couple hundred bucks later i t was a bad mass air flow sensor.
  16. Remove Advertisements
