Radio Quit
Results 1 to 12 of 12
Cadillac Catera and Cimarron Forum Discussion, Radio Quit in Past Cadillac Vehicle Discussion; Today my radio quit working while I was driving. When I parked the car, the radio works when I shut ...
    overplayed's Avatar
    overplayed is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera
    Nov 2004
    VA
    182
    Radio Quit
    Today my radio quit working while I was driving. When I parked the car, the radio works when I shut the ignition off an turns off when I open the door like it is supposed to but does not work at all any other time. The clock kept the correct time and the only other thing that is not working to my knowledge is the door locks do not lock when I put the car in gear and do not unlock when I put it in park. The door locks do work manually with the switch. I looked at fuses #6, #8, and #26 and they seemed fine. What else could this be? Anyone had this issues before?
    Thanks
    Jeff
    marko69 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera Sport, 1990 Porsche 944 S2 cab
    Jun 2011
    Tampa
    109
    Re: Radio Quit
    Probably everyone's favorite little buddy.......relay K134. Do a search on radio and you'll find that this is most likely the problem.
    overplayed's Avatar
    Nov 2004
    VA
    182
    Re: Radio Quit
    I found that my #10 fuse was blown. I replaced it but it blew again as soon as I turned the radio on. The #10 fuse is listed for Body Control Module, Heater water auxiliary pump, fan control relays, auxiliary water pump relay. Where is the heater auxiliary pump at? I have had a weird noise coming from under the dash on the passenger side, maybe that's what I blowing my fuse.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Very possible, fuse is blue 15amp???
    Jun 2011
    Tampa
    109
    Re: Radio Quit
    It's underneath the coolant resevoir.
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Search here on forum, u can find alote of threads abiut pump + pictures!!!
    overplayed's Avatar
    Nov 2004
    VA
    182
    Re: Radio Quit
    Both water pumps looked dry. I have had the flu, so I have not had a chance to pull the relay to look at it.
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Quote Originally Posted by overplayed View Post
    U are not gonna see any thing on relay, +u need to open it, just order one over ebay or rockauto and replace it, if its not gonna work u always can send it back.
    U can find video on YouTube of location.
    In my case my radio was out, trunk and fuel door was not opening. As soon as I replaced it, it's work just fine.
    Jun 2011
    Tampa
    109
    Re: Radio Quit
    You say fuse #10 blows when you turn the radio on? None of the items off of fuse 10 have anything to do with the radio except the BCM. I would disconnect all the items off fuse 10, except the BCM, and then see if the radio still blows the fuse. If so, I would suspect the BCM, or the radio (and possibly K134 as it gets its ground thru the BCM for hot at all times). Items off fuse 10, per the schematic, are what you have listed plus the heated seat switches driver and pass.
    On the pumps operation, just see if it is vibrating. With the car running, feel the pump, then unplug the power cable and see if it changes. Have the heat on also, not sure if it should be running or not if the heat is off.
    overplayed's Avatar
    Nov 2004
    VA
    182
    Re: Radio Quit
    I believe the issue is caused by one of the aux water pumps. I unplugged the pumps and replaced the #10 10 amp fuse and everything else was fine. Today I will plug the pump nest to the wheel well back up and see if that bows the fuse. My radiator used to leak on the other pump and I suspect that will be the issue. If either pumps blow the fuse individually I would suspect the relay or pcm.
    Jun 2011
    Tampa
    109
    Re: Radio Quit
    If either of the pumps blow the fuse, I would suspect the pump. A burned up motor in the pump can cause the excessive amp draw.
    overplayed's Avatar
    Nov 2004
    VA
    182
    Re: Radio Quit
    What I meant by if either pumps blows the fuse was if pump "A" blows the fuse while pump "B" is unplugged and in turn pump "B" blows the fuse while pump "A" is unplugged, then I would suspect the relay or pcm. Obviously if only one pump blows the fuse, it's the pump. When I went to plug in the pump on the wheel well this morning, I realized it was coated in coolant that dripped from the reservoir. I then just plugged in the pump at the radiator an didn't blow the fuse so hopefully I can clean the connection to the other pump and shield it frm the drips or stop the drips an not have to replace the pump.
  15. Remove Advertisements
