one side of my heating isnt working...
Results 1 to 10 of 10
Cadillac Catera and Cimarron Forum Discussion, one side of my heating isnt working... in Past Cadillac Vehicle Discussion; any ideas how to fix this problem.....
    gregbur is offline Cadillac Owners Member
    Automobile(s): Catera
    Jan 2014
    canada
    6
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Re: one side of my heating isnt working...
    The temperature on each side is controlled by a blend door under the dash that is moved by a small electric motor. Check to see that the door moves when you change the heat setting on each side.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Quote Originally Posted by gregbur View Post
    What side is not working ?
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    With my Catera, that was the last straw. Passenger wrapped in a blanket, while driver roasted. Couldn't turn off outside air in the wintertime
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Thats easy fix. What side?
    Jan 2014
    canada
    6
    it is the passenger side, it just blows like the AC is on..
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    REMOVAL PROCEDURE
    The passenger side air mix actuator is located on the lower RH side of the HVAC module. The actuator is below and forward of the heater core
    Remove the RF floor air outlet.
    Remove the passenger side air mix actuator cover screws.
    Remove the passenger side air mix actuator cover (1).
    Disconnect the passenger side air mix actuator electrical connector (3).
    Remove the passenger side air mix actuator screws (2).
    Remove the linkage (from the passenger side air mix actuator.
    Remove the passenger side air mix actuator.
    INSTALLATION PROCEDURE
    Install the passenger side air mix actuator.
    Install the linkage (2) to the passenger side air mix actuator.
    Install the passenger side air mix actuator screws until fully seated and not stripped.
    Connect the passenger side air mix actuator electrical connector (3).
    Install the passenger side air mix actuator cover (1).
    Install the passenger side air mix actuator cover screws until fully seated and not stripped.
    Install the RF floor air outlet.
    Synchronize the actuators:
    Turn the ignition switch to the ON position.
    Simultaneously press and hold the AUTO and OFF buttons on the H-A/C control panel for at least 5 seconds .
    Re-Calibrating Actuators After Power Loss
    After disconnecting the battery or experiencing a complete power loss, synchronize the electronically operated actuators as follows:
    1.Turn ignition to the RUN position.
    2.Simultaneously press the AUTO and OFF buttons (located on the heat and A/C control head) for at least five seconds .
    3.After initiation, the stepper motors will cycle from one stop to the other. You may hear the motors cycling while calibrating.
    Jan 2014
    canada
    6
    thanks very much, for your help
    josh42088 is offline Cadillac Owners Member
    Automobile(s): 97 catera
    Jan 2014
    31
    Mine is the same but drivers side I could deal but even with the top vents closed my legs freeze where do I look how can I fix it an can I just jerririgg it cause I have no ac anyways? Its a 97 thnx
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Easy fix too. My motor still was working when I puled it our. In side of assembly there are few gears, look in it, some gears might not touch each other because over time for some reason upper gear moves pin that its contented to, out of assembly and spot touching gears that inside.
    U can push that pin baick in with your fingers.
    Ill see if I can find pictures that I took while I was doing it
  13. Remove Advertisements
