strange coolant loss. Can't find any culprits.
Results 1 to 11 of 11
Cadillac Catera and Cimarron Forum Discussion, strange coolant loss. Can't find any culprits. in Past Cadillac Vehicle Discussion; So like title says I lost a little bit of coolant in a way where looks like an small explosion ...
    98Catera_2010's Avatar
    98Catera_2010 is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Cadillac Catera Sport
    Oct 2010
    Cookstown, Ontario Canada
    28
    242
    So like title says I lost a little bit of coolant in a way where looks like an small explosion under the hood. I inspected all hoses for cracks n leaks with no result, checked the reservoir no cracks anywhere. Before I got home I didn't have any smells or warning lights no drastic temp chance while driving, nothing. I have no leaks under car. I had just above half full in the res. So I topped up and started it with no leaks or spraying n no warning lights.
    Im so confused, what would cause this.? Any and all comments appreciated.
    Thanks
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by 98Catera_2010
    There's your problem, you're overfilling the system. There's supposed to be airspace over the coolant in the surge tank. This allows for expansion of the coolant as it heats up.
    Any excess coolant will be expelled.
    Oct 2010
    28
    242
    I always fill to the indication mark on the res. And it was down almost half from mark.
    But my mechanic friend found my leak on the rad hose.
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: strange coolant loss. Can't find any culprits.
    There is a valve on the back of the engine that is prone to leaking.
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    The heater bypass valve is a very common problem in Cateras. Follow a heater hose to the back of the engine and it will enter the plastic valve. It bypasses the heater core when the A/C is on full in the summer. Depending on the water flow through the valve, it may or may not leak at any given time. Sometimes it drips on the exhaust and instantly vaporizes so it doesn't show as a puddle under the car.
    Could also be the Aux water pump under the coolant reservoir. Kicks in to increase water flow through heater core. Possible that it only leaks when the heater is on full.
    Oct 2010
    28
    242
    Thanks guys its my lower rad hose, small little crack like a grain of cooked rice lol. Local part store doesn't stock or can even get them so ordering from Rock. Have a used one but want to go new.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Just extra info to this thread:
    I had coolant lost too and couldn't track it, I only had a smell of it on hot engine and had to add coolant every 2 weeks, no spots on the ground or drips was found. I was replacing my oil cooler and when looked on thermometer I found a small leak from gasket, coolant was leaking down to oil pan, under cams covers, exactly between cams. While it was leaking on hot block, coolant was evaporating.
    retho78 is offline Cadillac Owners Connoisseur
    Sep 2007
    1,024
    If in case the heater control valve (HCV) goes bad, go with this mod that I did on my car and so far no problems. I did this modification in 2009 and it's been over 4 years and still functioning well.
    Sorry forgot to post the link....here it is.
    http://www.cadillacforums.com/forums...relocated.html
    Thanks.
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Quote Originally Posted by retho78 View Post
    Are u talking about mod where moved HCV closer to coolant tank? If yes that was really good idea.
    Mine when out 3 times. Twice on used from junk yard, then I got one over ebay for around $25, didnt last long. Then I got second one for around $30 over ebay too, different brand then first one but now already two years pass and its working fine.
    Sep 2007
    1,024
    Yes, I bought the AC Delco brand from Amazon. I believe it was around $40 and no problems with it and also did the mod on my in-laws Catera 2 years ago and no problems with it.
    Seek_Low is offline Cadillac Owners Member
    Jul 2013
    26
    I was loosing enough for the Yellow radiator light to come in every 400 - 500 miles - Temperature was always in the "normal range"
    Eventually loss increased to the reservoir amount every 90 - 120 miles
    Discovered a drip from the auxiliary water pump {in the middle where the two halves are connected} located under the overflow reservoir
    Here is a link to the part for visual reference
    http://www.theautopartsshop.com/Sear...hText=55-17911
  14. Remove Advertisements
