Camshaft timing
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, Camshaft timing in Past Cadillac Vehicle Discussion; Hi everyone! I just had a blown head gasket and I'm putting everything back together and have ran into something. ...
    geason is offline Cadillac Owners Member
    Automobile(s): catera
    Mar 2013
    7
    Camshaft timing
    I'm putting everything back together and have ran into something. I didn't pay attention enough when I pulled the cam gears off. So here is my question now that I'm putting this back together.
    Does the pins on the camshaft point up lining up toward tdc? Being that the cam gear can go on two ways, I should have noticed, but didn't.
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Re: Camshaft timing
    http://files.spectralcoding.com/file...ing%20Belt.pdf
    Maybe this might help to see the pin marks. This was when I changed the timing belt.
    http://www.cadillacforums.com/forums...ml#post3355593
    Mar 2013
    7
    Re: Camshaft timing
    Thank you! The pins go on top!
