Oil leak and dripping on to exhaust pipe and causing light smoke
Results 1 to 4 of 4
Cadillac Catera and Cimarron Forum Discussion, Oil leak and dripping on to exhaust pipe and causing light smoke in Past Cadillac Vehicle Discussion; Okay, had some oil leaks that was dripping on to the exhaust area, so I changed the valve cover gaskets, ...
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Okay, had some oil leaks that was dripping on to the exhaust area, so I changed the valve cover gaskets, new upper and lower intake manifold gaskets, cleaned the black plastic lines, breather box and washed the under of the car but I can still see slight oil leak and smoke.
    I checked around the valve covers and everything looks dry and my only guess is now the exhaust manifold might be the issue because I can see it a little oily residue under the exhaust cover / shield area.
    or
    Could it be something else that's causing the slight leak and smoke or could it be the old oil that fell on to the exhaust shield area and it taking some time to dry out?
    Thanks.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Re: Oil leak and dripping on to exhaust pipe and causing light smoke
    Unless you cleaned the crankcase breather box you still have oil spraying on the exhaust heatshields. It's a build-up of internal pressure that causes the leak. The breather relieves this pressure. Read more:
    http://www.omegaowners.com/forum/ind...?topic=90653.0
    Sep 2007
    1,024
    The breather box was cleaned and air flows through it. I checked it before putting the valve cover gaskets on. Also no leaks from the valve cover gaskets so my only guess is probably head gaskets.
    I see some oil where the exhaust pipe meets to the block. More on driver's side.
    Sep 2007
    1,024
    Well, after driving it today I didn't see any smoke or leaks. I'm guessing it was the oil that leaked previously is burning away.
    I'll monitor it for few more days and keep you all posted...thanks.
    HAPPY NEW YEAR!
  7. Remove Advertisements
