Starter Problem When Cold
Results 1 to 7 of 7
Cadillac Catera and Cimarron Forum Discussion, Starter Problem When Cold in Past Cadillac Vehicle Discussion; I have a 99 Catera and for the last 2 weeks or so I have had a hard time starting ...
    w98seeng is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville
    Mar 2011
    55
    114
    I have a 99 Catera and for the last 2 weeks or so I have had a hard time starting my car.
    In the morning the starter clicks, like the solenoid is engaging but nothing else. I try about 15 or 20 times and it will finally engage and start the car.
    I can start the car 30 times during the day and no problems.
    Is it possible for the starter to get wet inside and freeze?
    Is there a rebuild kit I can get for the starter? How about new bearings/bushings? I know in some starters when the bearings/bushings wear out,
    the armature can touch the stator and short out the starter.
    I can see the bottom bolt from under the car, but how hard is it to access the upper bolt? Can I take apart the starter and do anything to help?
    Thanks,
    Ian
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: Starter Problem When Cold
    Check battery/starter for corrosion. When it just clicks, do the headlight work to full brightness?
    Mar 2011
    55
    114
    Quote Originally Posted by kaustein View Post
    Yup, all the electrics work fine.
    Ian
    Jul 2008
    712
    Quote Originally Posted by w98seeng View Post
    Ian
    Next time it clicks, tap the starter with a hammer a couple of times.
    Mar 2011
    55
    114
    Tried that, makes no difference.
    Ian
    Jul 2008
    712
    Well, I'd guess the starting is going. But on these cars, who the hell knows for sure!
    Mar 2011
    55
    114
    Last week we had one day that was above freezing and ever since that day, I haven't had any problems starting the car. The last couple of days it has been -28 (-18.4 Fahrenheit), with the windchill, it's been around -40. No problems starting that car at all.
    Ian
  10. Remove Advertisements
