K 134 multifunction relay
Results 1 to 8 of 8
Cadillac Catera and Cimarron Forum Discussion, K 134 multifunction relay in Past Cadillac Vehicle Discussion; Hope someone can help me I have an 01 Catera car has 188k miles runs like a top only problem ...
    dglad's Avatar
    dglad is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2008
    46
    30
    Hope someone can help me I have an 01 Catera car has 188k miles runs like a top only problem im having is the k134 relay keeps going out ive put 4 in my car so far will last 3-4 days then goes out I can unplug it plug it back in and will work foraybe a day but ive gotten 4 different relays and they all go bad any help will be greatly appreciated and by going bad I mean the radio trunk release and fuel release quit working.
    marko69 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera Sport, 1990 Porsche 944 S2 cab
    Jun 2011
    Tampa
    109
    Re: K 134 multifunction relay
    Could possibly be one of the ckts that the relay controls is drawing too much current. Not enough to blow the fuse but enough to burn up the relay over time. You could try pulling all the fuses on the ckts connected to k134 and see if the relay lasts. You could also check the current draw on each ckt.
    Certainly could be something else but this is one direction to take.
    dglad's Avatar
    Sep 2008
    46
    30
    Will do thanks
    libbysman is offline Cadillac Owners Fanatic
    Automobile(s): 1997 catera/03 CTS
    Jan 2009
    Vancouver, Canada
    152
    Hello All: Can the contacts on the relays in the K134 be cleaned up? I'm guessing that the contacts can accumulate crud after many years use. I've had problems with mine, and checked all the soldered connections on the back of the board. By the way, if one needs a new K134, where can they be purchased from?
    Regards, Brian
    Jun 2011
    Tampa
    109
    You can get a new one from Rockauto.com for $53, p/n 90494163. You can try hitting all the solder joints with a soldering iron in case there's a cold solder joint. Not sure if you can access the contacts to clean them or not. You can also try a used one from the junkyard for like $5.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    If im not mistaken I cleaned mine by spraying electric clean. I sprayed alot , kind wash it out. Electric clean was in red can. U can buy it any automobile part store or in walmart, its cheaper there
    Since that I don't have any issues. It did cut of on me few times since pass year. But thats not a big deal
    2kCatera is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac Catera
    Dec 2013
    1
    The trunk just went out tonight.... been having problems with the radio cutting off for a minute or two at a time, Will this relay fix the radio issue as well?
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Quote Originally Posted by 2kCatera View Post
    Yes it will.
  11. Remove Advertisements
