EBCTCM issues and replacement help
Results 1 to 6 of 6
Cadillac Catera and Cimarron Forum Discussion, EBCTCM issues and replacement help in Past Cadillac Vehicle Discussion; Pretty sure I need to replace the EBCTCM. Any advice on the process and best deals on replacement/repair is greatly ...
    wardgailey is offline Cadillac Owners Member
    Automobile(s): Catera
    Sep 2013
    65
    8
    Pretty sure I need to replace the EBCTCM. Any advice on the process and best deals on replacement/repair is greatly appreciated.
    overplayed's Avatar
    overplayed is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera
    Nov 2004
    VA
    182
    Re: EBCTCM issues and replacement help
    I just replaced mine on my 2001. I sent the module to BBA Reman to have it fixed for $60. I bought the service through Ebay but they have a separate web site. It is a true pain and test of patience to remove and replace. The brake valve that comes out with the EBTCM is twice the size of the module. I ended up just yanking mine out in anger. When I installed it, I removed the brake lines coming from the master cylinder and tied the others to the side. You should do that when you take yours out. You will also need to remove power steering reservoir. The clip on the wiring harness is also tricky. If you have the factory manual, the picture is wrong. The tab you have to pull out is on the same side the wires come out of. The tab is reddish in color and comes out about 1 1/2 inches. Hope this helps.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Quote Originally Posted by overplayed View Post
    I'm afraid you went a little overboard to remove the EBTCM. I had a EBTCM failure and removed it without all that work. Here's some advice I gave to another owner and he said he found it useful. Hope it helps:
    http://www.cadillacforums.com/forums...-question.html
    overplayed's Avatar
    Nov 2004
    VA
    182
    How did you get access to the bracket bolts? I just went and looked, I could see them both.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    I didn't say it was easy, just that you don't have to remove all the stuff that you did. I don't remember exactly how I did it but there was cursing involved and a u-joint attachment for my ratchet wrench. Once you remove the mounting bolts leave one loose to use as a pivot to tilt the ABS pump back. That gives you a clear shot at the EBTCM screws.
    overplayed's Avatar
    Nov 2004
    VA
    182
    Knowing how I did it and looking at how you did it, if I had to do again tomorrow I would try your way. Either way, its not fun. I didn't curse that much, but I had beer and plenty of time. Its not that it I hard to do, there I jut no space to do it. Tightening a brake line 1/20th a turn at a time, not fun.
  9. Remove Advertisements
