97 catera has coolant/ oil coming from throttle body!!
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Cadillac Catera and Cimarron Forum Discussion, 97 catera has coolant/ oil coming from throttle body!! in Past Cadillac Vehicle Discussion; Hey, I have coolant in my oil and is blowing white smoke. But the kicker..its massively coming out of the ...
    rswartz8910 is offline Cadillac Owners Member
    Automobile(s): 97 catera
    Nov 2013
    27
    8
    Exclamation97 catera has coolant/ oil coming from throttle body!!
    Hey, I have coolant in my oil and is blowing white smoke. But the kicker..its massively coming out of the throttle body!! Please help..Thanks
    Nov 2013
    27
    8
    Re: 97 catera has coolant/ oil coming from throttle body!!
    Im just curious if anyone has had a similar problem. I patched the side tank on the radiator filled it up and let it run and then once it warmed up it started smoking. The previous day I checked the oil and it was clean and no signs of coolant.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    I had same thing and all this gave me crazy miss fire too. Coolant was it intake, throttle body and got in oil. My mechanic find that my already previously replaced heater control valve broked inside and tight air hose that was connected to the vavle body on the top was sucking coolant. On running engine pull that hose and see if colant will leak from valve . If it is, replace valve and change oil twice!!!. Second time after 20 mile ride.
  5. #4
    Nov 2013
    27
    8
    You mean the really small vacume line out of the top of the heater by pass valve? Did yours dump the coolant oily mixture really bad out of the trottle body?
  6. #5
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Mine had more coolant in throttle body then oil. And yes vacuum line!
  7. #6
    Nov 2013
    27
    8
    I ran it for a ahort time and didnt see any coolant come out. Possibley head gasket is what im thinking.
  8. #7
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Oil cooler is common problem on early models.
  9. #8
    Nov 2013
    27
    8
    Do you think I should pull the intake and inspect or pressureize each cylinder? Im not sure on what I should do
  10. #9
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    U can. Its easy. Rent tool at autozone
  11. #10
    Nov 2013
    27
    8
    I just pressurized the cooling system and I can hear air coming from the oil fill tube. Id asume that means its time to put head gaskets in? Are these heads known for warping/ cracking? I dont know if the previous owner ran it hot or not but I had the temp guage a little below 3/4 before I knew I had a problem.
  12. #11
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Its still can be oil cooler!
  13. #12
    Nov 2013
    27
    8
    What do I need to look for when I disasemble? Will it be cracked? Any way of testing it?
  14. #13
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Its hard to tell. Until u take it off . And look on seal
    Let me post video youtube for u how to remove it
  15. #14
    Nov 2013
    27
    8
    Sounds great thanks!
  16. #15
    xbrandonwilsonx is offline Cadillac Owners Member
    Automobile(s): 1998 Catera
    Apr 2012
    Kansas City
    32
    9
    Just had this happen to me after a rebuild. Bought a brand new Heater Control Valve and it came bad in box. Took me multiple times of refilling and running to realize the culprit. I had just replaced my head gaskets too so it wasn't that. Also bypassed the cooler with an exterior aftermarket one... It's the vacuum line attached to the HCV if you've got anything in the throttle tubes. Plugged the vac line and swapped in a "T" connector just to see if the results would be different. Sure enough.
  17. Remove Advertisements
