Results 1 to 7 of 7
Thread: How to shut off winter mode
    jpgrod is offline Cadillac Owners Member
    Automobile(s): catera
    Jun 2012
    30
    9
    My winter mode stays on all the time and i go realy slow on take off. Is there a fuse that I can take out to shut this off or something ? And will this kill my engine or transmission if it stays on ?
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: How to shut off winter mode
    there is a snow flake button to the right of the shifter. push it in.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Shouldn't it default to off every time the car is started? Or is it not a momentary switch?
  5. #4
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Ice mode button by shifter could be stuck. Try to pull cover, it will come with plastic frame around shifter together with ice mode button and led for gears . Try to manually disconnect that button
  6. #5
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Snow mode can only be activated from a stop and is supposed to disengage upon reaching 30 MPH. It's not a momentary switch. Is the CEL on? Take the car to advanced auto or any other auto parts store and they'll pull the codes if any. My wild guess is if your snow mode isn't disengaging it might be the TCM (Transmission Control Module). Try disconnecting the battery for a few minutes and reconnect it. The TCM might reset. Avoid sparking the terminal. Something else might pop.
  7. #6
    Jun 2012
    30
    9
    Thanks for all the replies on further looking into the problem it was a fuse that blown. I just had to replace a fuse weird cause my steering went out and my sno tracked stayed on . I had to replace that !
  8. #7
    Jul 2008
    712
    The car is full of electrical gremlins! And that is putting it nicely.
  • You may not post replies
