Check Engine light not lighting up - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 47
Cadillac Catera and Cimarron Forum Discussion, Check Engine light not lighting up in Past Cadillac Vehicle Discussion; cad99 & PRSPower, The file has been sent..! cad99, sorry for the delay.. :O)...
  1. #31
    omermurat is offline Cadillac Owners Fanatic
    Mar 2005
    VA
    321
    Re: Check Engine light not lighting up
    cad99 & PRSPower,
  2. #32
    jeredenb Guest
    Omermurat, can you please send me a copy of the PDF. I forgot my email in the last post...It is j.redenbaugh@verizon.net
    Thanks,
    John
  3. #33
    Mar 2005
    VA
    321
    It's been sent.
    Good luck
  5. #34
    valle1018 is offline Cadillac Owners Member
    Jul 2004
    49
    Omermurat and AllenPacla,
    I am getting the code P0411 code as well.
    Can you please send me your procedures to fix this problem?
    Thank you.
    cesar.valle@asi.com
  6. #35
    Mar 2005
    VA
    321
    The file has been sent. Good luck
  7. #36
    stonecoldsteele is offline Cadillac Owners Member
    Sep 2005
    16
    [B][I]Can someone send me the same file? My check engine light has came on and it is the same incorrect air flow....It was supposed to have been fixed before I got the car but I think they just cleared the code so it could pass inspection....In my state if the check engine light is on they will not inspect it so i need to find a fix for it...Thanks...stonecoldsteele@bellsouth.net
  8. #37
    Mar 2005
    VA
    321
    The file has been sent. Good luck.
  9. #38
    Skip Robbins is offline Cadillac Owners Member
    Oct 2005
    1
    omermurat:
    Would you please send me a copy of your pdf file RE: the secondary air injection pump / P0411 procedure. Thanks. Please email to:
    omay@att.net
  10. #39
    aa2ac is offline Cadillac Owners Member
    Oct 2005
    1
    catera healer..
    Would you send me the pdf file on the P 0411 repair?
    Tnx
    aa2ac@srscales.com
  11. #40
    AllenPacla is offline Cadillac Owners Fanatic
    Nov 2004
    New York
    447
    I guess i have to make this post since I had the problem before and was able to figure it out with Omermurat's help. First thing to remember is that the Secondary Air injection system is initialized only during cold starts, so once the engine is warm enough it doesn't have to run. With the help of Omer's pdf file, one can easily identify the different parts that makes up the whole system. The only problem is that, in the pdf file, almost always, a scan tool is required to diagnose exactly which part is faulty. But i found a way to do it manually, but just like i said, it will require several cold starts which means you will be able to accomplish the complete diagnostics in probably 3 days of cold starting the car. The first thing you have to establish is if the air pump is okay. If you don't hear it operate during a cold start then it could be busted or probably just the relay. If you get direct power to the air pump and it runs, then it could be the relay that is not working. If you can establish that the pump runs every cold start, then you will have to move on to the other parts of the system. There are two valves in the system, one is the bell shaped aluminum valve located just before the pipes that leads to the exhaust and the other is made of plastic. If I'm not mistaken, the plastic one is called the vacuum cut-off valve. Anyway, the plastic valve opens and closes as the system is initialized. And it opens up with the use of vacuum pressure. If you look at it, there is a rubber pipe directly connected on top of it, that's the vacuum hose which connects to the control solenoid. When the system initializes, the control solenoid will let vacuum pressure through the hose and will cause the valve to open, letting air coming from the air pump through. Now, we get the dreaded engine light code because there is not enough air or there is no air that is passing through the system. Even though the air pump is running, if the valve is not going to open, air won't get through. So, to check which one among the two is faulty (Control Solenoid or the Valve), try directly connecting the vacuum hose coming from the engine into the plastic valve and try one of your cold starts and see if air will get through the valve. But of course, you will have to disconnect the big hose that connects to the other end of the valve, the one that leads to the exhaust. If after directly connecting a vacuum hose to the valve, you felt pressurized air is passing through then it should be working, try removing the vacuum hose and see if it closes back. After determining that valve is functioning properly, it is now safe to assume that the control solenoid is the faulty one. You can actually feel the solenoid clicking once the system is initialized during one of those cold starts. If the plastic valve is faulty, try replacing it first because it's cheaper and see if it will solve the problem. If replacing it will not solve the problem, then replace the solenoid. This is a long read i know, but i hope that it will give you guys an idea on how to diagnose the problem without using a scan tool. By the way, even if the aluminum check valve that i was talking about is not closing really tight, you don't have to worry about it because the plastic valve is enough to seal the system and prevent back flow of exhaust air into the air pump. Good luck
  12. #41
    rpgibbs is offline Cadillac Owners Fanatic
    Automobile(s): 06 SRX 05 CTS-V
    May 2004
    Estero, Florida
    122
    To Omermurat,
    I have a 2000 Sport that I am getting an error code P0411 and have seen that you have a pdf file about how to diagnose the problem. I would appreciate your sending this file to me (email address below) or if anyone else has the pdf file I would appreciate it if you would forward it to me. Thanks.
    rpgibbs@hotmail.com
  13. #42
    Nov 2004
    New York
    447
    You will need a Code reader that is used by GM technicians if you want to use the pdf file that Omer has. And not so many have that Code reader (which also sends commands to the cars computer) I just can't remember what it's called exactly. Anyway, I was able to diagnose mine when i had the problem by plainly using patience and a little of understanding how the system works. I guess i posted how I did it in this thread. You just follow what it says. Good luck
  14. #43
    R3dl3g is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2007
    1
    I have a check engine light on and the code is 0411. I thought it would be the idle air control valve or mass air flow sensor but now Im in doubt after reading this post. Sounds like a check valve from what I have read. If anyone has that pdf file that explains this problem a little more I would greatly appreciate it. Sgtdriggs@hotmail.com
  15. #44
    moerome is offline Cadillac Owners Member
    Automobile(s): '99 Catera
    Feb 2007
    Tupelo, MS
    64
    I'd like to get a copy of the PDF as well if you don't mind. Thanks a mil.
    moerome@bellsouth.net
  16. #45
    brohar is offline Cadillac Owners Member
    Jun 2007
    1
    I have the same code P0411 as well as some engine misfire codes. Car sounds funny. Can you give me any help? I dont work on cars usually but im about to start.
  17. Remove Advertisements
