  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: Alternator problem??
Old 04-08-05, 11:12 AM
View BLUCAT98's Photo Album
Casino Cash: $250
Hi all, Steve & Jeffrey..,
The car died on me 3 times the day before yesterday :madtalkin ! I immediately thought it was the alternator but I'd like to hear anyone's oppinion. I now realized that all along the car seemed to be running at a voltage range that's only half way up the 0-16 volt gauge in the Instrument Panel. That would only be 8volts ! I never thought a car could crank up on just 8volts??
On Wednesday I was cruising with my girlfriend when all of the sudden poof..., the car just died !!!!!!! The Check Engine light had poped up for a sec, I noticed the voltage being below 8 volts, probably just 7volts, then all was off! I managed to pull over to an empty metered parking spot and lucky for my girlfried she found the stores she was looking. Meanwhile I was outside trying to KICK THE CATERA OUT OF MY POOR CADILLAC!!
The car usually runs at just above the half way line on the Temp gauge. I tried to crank up the car again but it wouldn't go. It wasn't untill I oppened the hood and let the car cool for a hole hour that the car decided to turn back on. I immediately yanked my girlfriend out of the store and home we left to have this happen to us 2wice more before we got home!! The car would die at operating temperature and get back on the road when it was cooler!
Am I right to think its just the alternator and not some sensor? How can I test this out with a volt meter?
I've read lots of threads in this forum with similar symptoms that would point to the Idle Air Control valve (IAC), the Camshaft Position Sensor (CPS) or the CrankShaft Possition Sensor (CKP), but I still dont think it's any of that???
If it were one of these sensors, is replacing them something I can do myself? Do they require any special tools for calibration or glues, lubrication or anything I dont already have in the kitchen ??
I didn't want to go to the dealer to find the codes on the car fearing the dealer would finish off the car just to get my money!! I'm ordering the "3110 CANOBD2 Tool " code reader : http://www.iequus.com/item.asp?cid=10&pid=3110. I've seen it for $200.00 and supports the "KWP 2000 ISO 14230-4" OBD-II protocol used in my 98 Catera.
I dont have any tools but I'm willing to try swapping out the Alternator? Does anybody have clear procedures and tools needed? Removing the drive belt and getting it back in correctly adjusted worries me!!!
Please Help!!
  #2 (permalink)
Old 04-08-05, 11:33 AM
View AllenPacla's Photo Album
Casino Cash: $545
Re: Alternator problem??
I don't think half way of the voltmeter gauge is 8 because if i am not mistaken each line is a volt, so from 16 going to half way is 4 lines which makes it 12 volts. Just come to think of it, the manual said that the red line is critical volts level, which in your analysis would be 0 volts, i don't think anything will run at that voltage level. Anyway, I believe that Steve and Jeff would have a good answer to your other question.
  #3 (permalink)
Old 04-08-05, 02:37 PM
Chaztera's Avatar
View Chaztera's Photo Album
Casino Cash: $250
BLUCAT98,
If it is your ALT. here is a link that can save you some $.
http://www.cadillac-parts-dealer.com/parts.htm
  #4 (permalink)
Old 04-08-05, 04:29 PM
Casino Cash: $250
Thanks Allen,
I take it that your Catera also has the volt meter at half way then? My car would die only when warm and the volt meter would be at what you would concider 11 volts without a load - no AC on , fan blower nor extra light etc..? The needle would sit one line below halfway on the meter.
If this is normal then..., it looks like one of the sensors is bad!!
  #5 (permalink)
Old 04-08-05, 04:47 PM
Vesicant's Avatar
It takes the caek.
Cadillac(s): None :(
View Vesicant's Photo Album
Casino Cash: $11290
You can get your alternator tested either on a bench or in the car at say an Autozone. As well as get codes checked.
I would have it tested first, and then see what volts its actually producing. Sometimes the gauges in a car dont always tell the exact truth. In the meantime, check battery connections for corrosion and the ground strap.
  #6 (permalink)
Old 04-08-05, 05:38 PM
Casino Cash: $545
Jeff, where does the ground strap connects to? I also wanted to check on the grounding of mine, because i am thinking that it may be contributing to the voltage going down when some accessories are on.
  #7 (permalink)
Old 04-08-05, 06:48 PM
Casino Cash: $250
I'll have the Alternator checked first, thanks!!
Is there an OBD code for an under-performing Alternator??
  #8 (permalink)
Old 04-08-05, 08:23 PM
Vesicant's Avatar
It takes the caek.
Casino Cash: $11290
Yes there can be. Usually it'll be about a system in the car not recieving enough voltage.
When your alternator is getting checked, do the battery as well.
  #9 (permalink)
Old 04-08-05, 08:27 PM
Vesicant's Avatar
It takes the caek.
Casino Cash: $11290
To a good metal to metal location on the frame. The two bolts with wires connected on the front of the battery sitting atop the insulation are the straps if im correct on this.
  #10 (permalink)
Old 04-11-05, 02:30 PM
Casino Cash: $250
Ok..,
It seems to be a sensor problem. My code reader only gives the "P0335 - Crankshaft Possition Sensor A Circuit". The only thing is that it doesnt say since when (date) the trouble was detected!!
Can I erase the code off the on board computer and should it re-appear with a quick short drive arround the block? I dont want to drive the car too far!!!
  #11 (permalink)
Old 05-02-05, 11:54 PM
View Cat_Beatle's Photo Album
Casino Cash: $250
try to clean up the crackshaft postion sensor first. The end of the sensor might be sticked with some dirt so that it would not sense any signal.
It is very easy. Go underneath the engine to unplug the sensor. Then clean it up with a soft cloth. Then put it back in.
  #12 (permalink)
Old 10-12-05, 12:38 AM
View CoolHandLinc's Photo Album
Casino Cash: $250
Hi!
I am researching an alternator problem on my mothers catera. So I can answer a few questions I have seen.
Ground cables I did trace out go to the right front of the engine block behind an accessory. Another junction of ground cables attaches to the body just to the back of and below the battery itself.
The voltmeter in the car. The top of the red zone is 11 1/2 volts. This isn't enought to charge. The large lines are volts and the smaller lines in between them are 1/2 volts. So count down from the 16 volts at the top of scale.
Can anybody tell me where the regulator is for the alternator? It has on somewhere among all the relays. I don't have a book and would like any specific data and a wiring schematic if possible,
Thanks
Tags: ,
alternator, problem
attach your bluetooth cell phone to onstar
flash wax for your cadillac
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum
