Need a little help from my friends.
Results 1 to 7 of 7
Cadillac Catera and Cimarron Forum Discussion, Need a little help from my friends. in Past Cadillac Vehicle Discussion; Hello guys, this is my first post to the forums. I own a 01' Cadillac Catera. Recently I had the ...
    CodyCatera is offline Cadillac Owners Member
    Automobile(s): 01' Cadillac Catera
    Sep 2013
    21
    13
    Recently I had the ECM replaced and reprogrammed. Then had the fuel pump/fuel filter replaced.
    Before I dive into details. The car sat for 8 months before we started working on it. I didnt leak any coolant/oil.
    After getting the car back from a family mechanic I started to notice that the car leaked oil. My brother and I did an oil change putting in 6qts of brand new oil. After doing that it still continued to leak. We pin pointed the leak to (what I believe is the bell housing) two bolts that face down behind the engine. once the car gets hot it starts to drip slowly. Today after I came home from school I popped the hood and there was some smoke (Happens after I drive mostly everytime. I look next to the pipe that you add oil too (oil downstem?) and noticed oil sitting on the lip on the valve cover. Before the car sat we replaced the spark plugs, and notice that the plugs had oil on them.
    I'd like to get some information, any kind will help. What to do first? How to? What can I do to find the exact problem?
    Thanks,
    Cody
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Re: Need a little help from my friends.
    Welcome to the funny farm that is the Catera/Cimarron Forum. To get to your problems I suspect the oil leak was due to 8 month lay-up. The engine's rear main seal might have shrunk from lack of circulating oil. I'd try some of the treatments like Marvel Mystery Oil or one of the Lucas products. Look for the ones advertised to rejuvenate/swell engine seals. If that doesn't work new seals may be in your future.
    The smoke is easier to diagnose. The camcovers are leaking. Oil drips on the exhaust manifold heatshields and smolders. While the car is moving the air flow carries it away but when it stands still the smoke collects under the hood. Many blame it on the plastic camcovers warping but I disagree. Your crankcase breather is clogged with sludge. As the pistons reciprocate they pump air and the crankcase pressure builds. Normally this pressure is relieved through the breather but when it's clogged it builds and seeks the next best exit. The covers, being plastic, lift and spray oil past their gaskets. Clean the breather and your problem may be solved. If not then new gaskets will be necessary. Either way the breather must be cleaned. It's a maintenance point but often overlooked.
    Sep 2013
    21
    13
    Could you tell me where the breather is?
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Refer to this earlier post. It contains links to 2 instructional articles from 2 Omega forums in England. Each has instructions. The second link contains pictures. Both are courtesy of their respective owners clubs.
    http://www.cadillacforums.com/forums...ml#post3287738
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Don't waste your money on the snake oil. Save up and replace the seals.
    Sep 2013
    21
    13
    Whats the general process in replacing the rear main seal? I've only got a few people that would help me on my Catera and I dont have a car lift to get underneath it. Im using ramps and jack stands at the moment.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    I also have a leaking rear seal but haven't had the time to get it fixed. I found instructions with pictures on the Omega Owners Forum (by J. Seaman). The Adobe document outlines an engine rebuild but includes the rear seal replacement. He removed the engine to perform the work. If you had access to a car lift you might be able to do it by dropping the transmission but using ramps I don't think it's possible. I'm by no means an expert so I could be wrong. Maybe you could rent an engine hoist plus a stand and the work that way. My cousin Kevin has his own repair shop and will be doing my car when the time comes. I don't know where you're located but if it's anywhere near the Bronx I'm sure he'd fix you right up. Good luck bud.
    http://images.omegaowners.com/images...ineRebuild.pdf
  10. Remove Advertisements
