codes p0650 MIL
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, codes p0650 MIL in Past Cadillac Vehicle Discussion; changed light out, drove for 100 hundred miles and still coding p0650 will not pass inspection. check engine light is ...
    roger ashworth is offline Cadillac Owners Member
    Automobile(s): 2001cadillac catera
    Aug 2013
    3
    codes p0650 MIL
    changed light out, drove for 100 hundred miles and still coding p0650 will not pass inspection. check engine light is not on.. any sugetions on how too reset?
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    DTC P0650 Malfunction Indicator Lamp (MIL)
    U need to replace burned out check engine light bulb on dash board.
    Aug 2013
    3
    Re: codes p0650 MIL
    i changed light, it comes on when starting car and goes off as it should when car is running...????
    waco-brian's Avatar
    waco-brian is offline Cadillac Owners Fanatic
    Automobile(s): Catera 98 & 99
    Apr 2010
    Waco,Texas
    50
    113
    Yes light should go out after the car starts up. Are you getting any more codes?
    Aug 2013
    3
    Re: codes p0650 MIL
    finlly passed inspection i guess did not drive long enough to reset...runs good..no more codes....changed light out on dash very easy to do...
  8. Remove Advertisements
