tech help needed on Catera temp gauge
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, tech help needed on Catera temp gauge in Past Cadillac Vehicle Discussion; Got a 2001 Catera with a non working temp gauge. Did the basics plus some. Replaced the sensor that the ...
    caddyguy31406 is offline Cadillac Owners Member
    Automobile(s): several
    Aug 2013
    53
    3
    Questiontech help needed on Catera temp gauge
    Got a 2001 Catera with a non working temp gauge. Did the basics plus some. Replaced the sensor that the blue wire goes to on the cylinder head under the intake. Ran a new wire from said sensor directly to pin 21 on the IPC connector. Replaced the IPC with a brand new one from dealer, and tried one from salvage.
    If you have the engine warmed up and the key turned to run when you push the cluster in place the gauge will rise and show temperature. If you start the engine it will fall to the peg rest. It won't come back up unless you remove the cluster for a period and reinstall with warmed engine and key on. If you directly ground pin 21 the temperature light will come on in about 5 seconds but the gauge does nothing.
    On the connector only 1 pin has ignition power. Both grounds show good as well as the constant power shown by alldata.
    Any suggestions?
    waco-brian's Avatar
    waco-brian is offline Cadillac Owners Fanatic
    Automobile(s): Catera 98 & 99
    Apr 2010
    Waco,Texas
    50
    113
    There is another connection back over the crossover that is the same as the temp sensor.make sure you didn't mix them up.
    Aug 2013
    53
    3
    Re: tech help needed on Catera temp gauge
    We removed the intake and replaced the sensor. Then ran a new wire from the sensor direct to the terminal 21 removing the original wire. It shows the ohms change as the engine warms but does not move the gauge. Thank you for the suggestion.
    Aug 2013
    53
    3
    Anybody else?
    atikovi is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Professional Chassis Raised Roof Presidential Limousine
    May 2003
    Suburban Washington DC
    400
    You bought a new instrument cluster from the dealer? How much did that set you back? If you plug in an OBDII scanner, see what the engine temp shows from there.
  8. Remove Advertisements
