my catera has a lound rattling sound. plus its underpowered!! help!
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, my catera has a lound rattling sound. plus its underpowered!! help! in Past Cadillac Vehicle Discussion; My catera sounds horrible. Hit a bump now it sounds like a diesel and its horribly underpowered. It says random ...
    boogie3309 is offline Cadillac Owners Member
    Automobile(s): 99 catera
    May 2013
    25
    Unhappymy catera has a lound rattling sound. plus its underpowered!! help!
    My catera sounds horrible. Hit a bump now it sounds like a diesel and its horribly underpowered. It says random or multiple misfire. Car still fires right up! Please help!!!
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Re: my catera has a lound rattling sound. plus its underpowered!! help!
    I wonder if a portion of the exhaust system came loose. Worth a check.
    reaper56 is offline Cadillac Owners Member
    Sep 2013
    1
    My had the same problem, i think it was the drive line and the sound it was the rear gears was grinding. And yes it wroth getting check because my car was nearly moving down the road before I got it fix.
    ReidHj is offline Cadillac Owners Member
    Automobile(s): 1999 Catera
    Aug 2011
    1
    Sounds similar to symptoms my Catera experienced recently and it was the catalytic converter starting to come apart. Internals were breaking off and then getting lodged in the muffler, causing the system to clog and leading to back pressure. I'm still looking for a replacement catalytic converter.
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    36
    449
    I kinda had the same issue... I repalced both cat converters with aftermarket. the cost to me was $240. mine where missing the guts of the cats, so it sounded like a tin can when accelorating... after I had them replaced the car had much more power.
    You need to go to a shop that will use aftermarkets.. saved $750 for me!!!! I may still have the tab home from the convertors I used... I can check.. I belived they are both a Mid bed o2 sensor, and 2 1/4 or 2 1/2" pipe... its been a while for me.... so Im not sure if I still have the think at home... but a generic convertor can be used, it just has to have the MID o2 sensor port.
    Have the car put in the air and rap on the convertors, you should hear stuff moving around.. or with me they had me sit in the car on the lift and rev it to listen to it.
    http://www.ebay.com/itm/MagnaFlow-94...6ba890&vxp=mtr
    here is ebay link to what you need... mine was 00 catera im unsure of your yr, so verify you have o2 sensors.
    he used 2.5" on mine, but I remember he had to size it down, so 2.25 " should be perfect for you.. mine where easterns that he used, about the same price as these.
  8. Remove Advertisements
