87 Cimarron Problem
Results 1 to 2 of 2
Cadillac Catera and Cimarron Forum Discussion, 87 Cimarron Problem in Past Cadillac Vehicle Discussion; Hi All; I saw this forum in my search for Cimarron information and figured it would be a good place ...
    scorpius666 is offline Cadillac Owners Member
    Oct 2003
    42
    Unhappy87 Cimarron Problem
    Hi All;
    I saw this forum in my search for Cimarron information and figured it would be a good place to ask a question.
    I am working on my fathers 87 Cimarron (2.8 engine) as it has a noticible loss of power and a stuttering (miss) on the lower rpms which is less noticible on the higher rpms. I replaced the wires and cleaned the plugs and it helped but still no cigar and the problem persisted.
    I took a florecent light to the ignition wires at night to test the spark and noticed 4 of the wires flashed the bulb nicely while 2 of the wires made it glow but very dimly. I traced the wires back and noticed they BOTH led to the third ignition coils located on the right. I am assuming it is dead or partialy functional and causing the problem ..... is this a correct assumption and what would a new coil cost???
    If the coil is dead could a forum member post a good and quick way to replace it as I noticed it is a very tight fit between the radiator and located rather low down on the engine.
    Any replys and help would be greatly appriciated and thank you in adavance.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: 87 Cimarron Problem
    Sorry you didn't get any help here. I'm wondering if you've had any luck fixing the problem...
    If this site has helped you save money, please consider helping it continue to do so. Click here for information!
