Compression PSI for 1997 Catera
Results 1 to 2 of 2
Cadillac Catera and Cimarron Forum Discussion, Compression PSI for 1997 Catera in Past Cadillac Vehicle Discussion; Does anyone know what the psi is for a compresstion test. I have to check one of my cylinders and ...
    poohjlg is offline Cadillac Owners Member
    Jul 2013
    1
    Does anyone know what the psi is for a compresstion test. I have to check one of my cylinders and need to know the psi. Thank
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,826
    Re: Psi for 1997 catera
    Within 10% of the other 7 cylinders, engine warm, no spark plugs installed, throttle blocked wide open, ignition disabled, at least 3 full crank rotations. Probably around 155# or so.
    If a cylinder is low, squirt in a half teaspoon of engine oil. Now, if the compression comes up, it's ring problems; if the compression stays about the same it's a bad valve.
