Catera Aftermarket/Performance Options
Results 1 to 12 of 12
Cadillac Catera and Cimarron Forum Discussion, Catera Aftermarket/Performance Options in Past Cadillac Vehicle Discussion; Since there have been so many requests, here are some possible solutions for performance additions and exterior modifications. These are ...
    Vesicant's Avatar
    Vesicant is offline Cadillac Owners Connoisseur
    Automobile(s): None :(
    Nov 2003
    Jacksonville, FL
    2,703
    Since there have been so many requests, here are some possible solutions for performance additions and exterior modifications. These are the best we've found so far:
    __________
    http://www.irmscher.de/com/
    Irmscher- I dont know if they will send to the US. Call them or email them.
    Part specification is the same as above. On the side bar, go to Accessories Programme > Omega > Till 1999 (97-99) or From 1999 (2000 -) > Saloon only. Catera is 3.0 V6, Lucas Brakes. Dont select estate/caravan.
    __________
    http://www.courtenaysport.co.uk/default.htm
    Again, not sure on their status on shipping to US.
    Go to Tuning > V6 Tuning. Most things should theoretically work except for all of the throttle bodies, and the items for the 2.5 V6 unless it also says 3.0 V6 is compatable as well. For example, the power chamber resonator works on both engines.
    __________
    Http://www.tirerack.com Various brake applications, tire, suspension.
    Http://www.knfilterchargers.com/search/appsearch.aspx - Hi-flow replacement airfilter. Part # 33-2734
    __________
    http://www.drivewire.com/ - Sparkplug wires (97-98), Intrax lowering springs (must disable rear leveling system!) and camber kits.
    Http://www.ultrarev.com/ - Magnacore leads, ignition.
    (thanks 97 Catera)
    __________________________________________________ _______________
    (I am not endorsing use of any of these products. I myself have not tested each item for its compatibility so I cannot guarantee that it will work. Aftermarket accessories may void your warranty or alter the operation of the pollution control systems on your vehicle. Use at your own risk!)
    aarontompsett is offline Cadillac Owners Member
    May 2005
    kent england
    37
    Re: Catera Aftermarket/Performance Options
    maybe try www.regal-shop.co.uk thats where i buy stuff for my omega the english version i highly recomend the bastuck exhaust systems i fitted one to my car they replace both center sections with a single section and join into one section at the cats and have no silncers at all very loud but sounds so sweet
    Vesicant's Avatar
    Nov 2003
    Jacksonville, FL
    2,703
    Awesome! Thankyou for the site... there are some nice upgrades on there'. :coolgleam
    Morhill is offline Cadillac Owners Member
    May 2005
    5
    Where can I find headlamp assemblies for 2000 Catera? My left headlamp insides have come loose---they still work, but cannot align correctly...Luis
    newbee is offline Cadillac Owners Member
    Automobile(s): 97 Catera
    May 2005
    colorado
    29
    57
    So, if i get one of those exhaust systems it will all fit and work on my 97 3.0 catera
    Caterror is offline Cadillac Owners Member
    Aug 2005
    24
    If I could only get this kind of dedication from the guys at work, I'd be rich. You've given me some great info over the past year since I bought the Catera Jeffery, Thanks.
    (Formerly Catscnfly but switched servs. and couldn't get back in without changing name.)
    ondale is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera Sport
    Mar 2004
    Chicago
    147
    I am just looking for a cool billet or mesh grill for a 97 catera. E&J classics use to make them, but they are discontinued. I like the all black ones that are available in the UK, but if someone knows where I can get one in the USA, it would be appreciated.
    caddy4sho is offline Cadillac Owners Member
    Jul 2004
    74
    heres the cheapest one I've found its $219
    http://customcaddy.com/xcart/product...1&cat=0&page=1
    miahcornell's Avatar
    miahcornell is offline Cadillac Owners Member
    May 2005
    michigan
    81
    our stock grills go for alot on ebay. I believe I saw a used one go for $250 before.
    Milehigh5000's Avatar
    Milehigh5000 is offline Cadillac Owners Member
    Automobile(s): catera
    Mar 2004
    5
    how bout some rims that will fit a 2000 catera sport? i've been kind of hesitant about gettin rims because i wanna go bigger. like 18" or 19" even. i have the 17" sport alloys now but i'm just not sure if 18's or 19's would fit on my car. if the bolt pattern is 5x110 but it's 18 x 8 will that work? because i know the wheel now is 17 x 7.5..please help
    CHRIS_B is offline Cadillac Owners Member
    Oct 2005
    4
    Hi, i am from the UK, i have the omega which is the same car as the cetera, the correct size for the wheels are 265/35/18 rear and 235/45/18 front the rears are 9" and fronts are 8", if you get the stienmetz i think the rears are10", just make sure you get the correct camber or you will chew your rubber to bits
    revin24 is offline Cadillac Owners Member
    Nov 2005
    15
    Thumbs upRe: Catera Aftermarket/Performance Options
    i found a cam site http://www.pipercams.co.uk/NewPiperW...0contents1.pdf
    they have a cam set that is rated a 30 hp they also have another cam set that dosent have a hp rateing but GUARENTEED ITS MORE POWER
  15. Remove Advertisements
