Catera Stalls.. starts/runs after sitting... then stalls again
Results 1 to 8 of 8
Cadillac Catera and Cimarron Forum Discussion, Catera Stalls.. starts/runs after sitting... then stalls again in Past Cadillac Vehicle Discussion; Could somebody/ anybody PLEASE help me with this problem? My '99 Catera just turned 170,000 miles and aside from some ...
    gjinx is offline Cadillac Owners Member
    Automobile(s): Catera
    Oct 2004
    Cleveland, OH
    12
    Could somebody/ anybody PLEASE help me with this problem? My '99 Catera just turned 170,000 miles and aside from some of the common Catera problems. Mine has seen very little time in the repair shop. Until recently. My Catera just spent three days in the repair shop/ I dropped it off there because my brakes were very soft (could barely stop the vehicle) so sa few days later; new brake lines installed; and several hundreds of dollars (of course). I was driving the car home when it stalled so I let the car sit for a few minutes before it would start. After driving it 1 mile it stalled again and it stalled again a third time just feet from the driveway so I pushed it the rest of the way. Now Im about to call a tow truck to take it BACK to the repair shop If anyone has any advice or remedy for this problem I would greatly appreciate some help
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The first step is to have the codes pulled.
    Next time it won't start, remove the gas cap, put your ear up to it, and have a helper turn the key to the ON position. See if you can hear the fuel pump running.
    marko69 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera Sport, 1990 Porsche 944 S2 cab
    Jun 2011
    Tampa
    109
    Re: Catera Stalls.. starts/runs after sitting... then stalls again
    I'm curious, the shop replaced only the brake lines to fix the problem?
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Crankshaft positioning sensor may be the problem. VERY common issue your description is symptomatic of a CPS problem
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    37
    449
    I was thinking CPS also. Odd that it restarted right away though.. or did it have to sit for a bit to cool off?
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    I wouldn't say that! In my case I just couldn't start engine right away. Engine was starting after like 3-5 cranks and then running just fine till I shut it off. Cam shaft position sansor failed same way but before crank sensor
    olddavid is offline Cadillac Owners Member
    Automobile(s): 93 Eldorado(sold)99 SLS(sold) 98Catera
    Mar 2007
    Depoe Bay, Oregon
    58
    My car had similar problems, but disconnecting the MAF allowed me to drive it until I got the O2 sensor it needed to operate correctly. I may be completely off base on this, but our cars require creative thinking to diagnose. Of course, the crank and/or cam sensors could also be faulty, but the disconnect of the MAF is quick and easy and if it doesn't help, you've eliminated one more possibility.
    Sep 2010
    East Boston MA.
    29
    26,325
    Disconnecting the MAF will allow the car to run of the MAF is faulty, it has nothing to do with the O2 sensors. And faulty O2 sensors will not cause the OPs symptoms.
  11. Remove Advertisements
