Amp installation
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, Amp installation in Past Cadillac Vehicle Discussion; I have 01 Catera, I'm wanting to install a sub and amp. Does anyone know where to run the 12v ...
    Stewie2395 is offline Cadillac Owners Member
    Automobile(s): cadillac catera
    Mar 2013
    22
    Amp installation
    I have 01 Catera, I'm wanting to install a sub and amp. Does anyone know where to run the 12v positive from the rear to the batter? Such as any openings in the firewall.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Not gonna work right !!!! U can burn everything around. U have to wire positive right from battery !!!! Negative u can attach to the body any where in your trunk. Run it on spare side , find drain hole for rain and run it from there under your car to the battery, to run to battery u can use hole right where your brake lines at by driver side tire, easy to find
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    I would strongly suggest running all wiring INSIDE the car.
