97 Catera hard to start
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, 97 Catera hard to start in Past Cadillac Vehicle Discussion; sometimes it starts up normally, sometimes it wont unless you crank it for a long time...here is what i know ...
    Caterastrophy is offline Cadillac Owners Member
    Automobile(s): Catera
    Mar 2012
    50
    3
    sometimes it starts up normally, sometimes it wont unless you crank it for a long time...here is what i know and have replaced:
    Replaced coil, 75.00 bucks, 116.00 witho overnight shipping, coil was bad one one bank,
    Replaced plugs
    Replaced valve cover gaskets
    Replaced fuel filter, clean anyway
    check fuel pressure, was over 45 to 50
    125lbs each cylinder, give or take 1 or 2lbs, very close
    after replacing coil it was running fine, come out the next morning and no start, crank for a long time finallys started, acted like it was flooded and smelled like strong fuel smell.
    started having a hard time starting.
    Replaced CPS, since i had this issue on another catera previously, but no change...
    i am thinking maybe regulator...I have spark, fuel, pressure, 125lbs compression, once it runs it runs great, but does miss at idle once in a while...
    any ideas would be greatly appreciated...
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Re: 97 Catera hard to start
    cam shaft position sensor and crank shaft position sensor will make car not to crank or crank after few times
    missing at idle could be due to air leak i have dropping idle on stops some times and could not find issue with that for over a year now
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    37
    449
    Ok, since your smelling fuel I'm going to say its what I had, stuck fuel purge valve! Under plenum
