timing belt kit recommendations?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Cadillac Catera and Cimarron Forum Discussion, timing belt kit recommendations? in Past Cadillac Vehicle Discussion; Hi, I'm planning to replace the timing belt kit while fixing the oil leak by the crankshaft gear / pulley ...
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Hi,
    I'm planning to replace the timing belt kit while fixing the oil leak by the crankshaft gear / pulley area and looking for some recommendations on what brand to go with.
    Gates
    Dayco
    Continental
    AC Delco
    Thanks.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    ACDelco ! Get new water pump too. And all new seals around cams and crank shaft
    Sep 2007
    1,024
    Re: timing belt kit recommendations?
    I have a new pump with me, so to change the seals around the cams....is it hard? Do I have remove more stuff out of the way to get to the can seals?
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    well u have to remove cams, all 4 of them and crank pulley shaft, but it worth to do. if they will leak latter just imaging to do all this job again !!! and dont buy cheep seals, get acdelco. look up at rockauto - ACDELCO Part # TCK285AP for $224.99 its have all seals and tensioner + get also new timing cover seal VICTOR REINZ Part # JV5103 for only $8. if u never done that kind of job. DONT DO IT !!!! its not that simple like u think !!! its took me whole week to do + u have to use special tools to tight pulleys!!!!! they not just regular pulleys, they adjustable ones. to tight them correctly i went to sears got big socket and center bolt that hold whole pulley had to replaced with hex bolt.
    J 42069 Timing Belt Alignment Kit
    tool form kit that u need to tight pulleys
    due to fact that u will replace seals u will need only cams stoppers for installation and to remove bolts that hold cams. i personally did not use this tools and use two bolts that fit perfectly between teeth of cams to secure them for installation.
    PDF Instructions on my Dropbox form my AllData By Web2PDF
    Part1:
    https://www.dropbox.com/s/pv9lqgnlq5...0Resonator.pdf
    Part2:
    https://www.dropbox.com/s/kn55yt9jca...-%20Intake.pdf
    Part3:
    https://www.dropbox.com/s/9a5khs5cfv...3-%20Cover.pdf
    Part4:
    https://www.dropbox.com/s/s9xpmb4tun...ing%20belt.pdf
    98Catera_2010's Avatar
    98Catera_2010 is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Cadillac Catera Sport
    Oct 2010
    Cookstown, Ontario Canada
    28
    242
    Me and my father-inlaw have done 4 timing belt Jobs on these cars, once on his first Cat, on his second Cat and my Cat when we did head gasket Job and again last month when my timing belt went and blew the engine and all we used were vice grips to hold them in place.
    Sep 2007
    1,024
    I was thinking about vice grips or c clamps. Just not sure about removing the cams to replace the seals. Does the cams sprockets have marks on it so it can go back only one way?
    Thanks for the PDF links I'll look into it and go from there.
    Also, for removing and installing the cams do I need additional tools other than the timing tool kit?
    Sep 2007
    1,024
    It looks like I may have to get the cam seals too because I see some oil residue on upper side of the timing cover now.
    I found out that Gates sells the same timing kit and it's much cheaper.
    Sep 2007
    1,024
    I'll probably follow this video also. This is for a Saab but pretty sure it'll work for the Catera and CTS 3.0 engine.
    http://www.youtube.com/watch?v=WMXaw4xgogQ
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    That's nice video. wish it was maid earlier! it took me 2 week to get my car back on road. first week i was putting all back, even called mobile mechanic, that he helped me to install that belt back correctly, but that (good mechanic) put it wrong and one tooth was loose. so i had to drive home like that, cuz my friend kick me out from his garage been there whole week, so i had to re-do everything again at my apartment complex parking lot.... i did not replaced seals, wish i could, i replaced only one pulley, others i cleaned and re-lube. since that time 3 years pass, no problem.
    Sep 2007
    1,024
    Okay, I'm planning to change the seals too because they might be leaking due to oily residue on the timing cover ....only will know once i remove the cover.
    Sep 2007
    1,024
    Okay, so I did a quick look on the timing belt behind the timing cover and noticed that there is oil all over and the belt has too many tiny cracks on it. I'm planning to order all the parts tonight.
    Thanks
    Sep 2007
    1,024
    Does the AC compressor have to come out to replace the oil pump gasket and crankshaft seal?
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    No!!!!
  16. #14
    Sep 2007
    1,024
    okay, good and thanks. I was looking at an online instruction and it says the compressor has to come out. Anyways, ordered all the parts and the timing tool. Planning to work on the car this coming Thursday - Sunday, a little at a time.
    http://www.justanswer.com/car/1c8u8-...ac-catera.html
  17. #15
    Sep 2007
    1,024
    Also, should I drain the oil to replace the oil pump gasket? The reason I'm asking is because I just changed the oil couple weeks ago.
    Thanks
  18. Remove Advertisements
