1998 Catera Cranks, not firing, no fuel pressure.
Results 1 to 2 of 2
Cadillac Catera and Cimarron Forum Discussion, 1998 Catera Cranks, not firing, no fuel pressure. in Past Cadillac Vehicle Discussion; New to me 1998 Catera w/ 60,000 miles. Turns over, will not start. So far I have: Replaced crank sensor ...
    DJBarney99 is offline Cadillac Owners Member
    Automobile(s): 1998 Catera
    Mar 2013
    57
    1
    Replaced spark plugs
    Replaced valve cover gaskets
    New battery
    New (used) ECM (popped cover on original and there were three burnt resistors)
    New vacuum fittings various to replace leaks
    I have checked all fuses and relays
    Checked coil pack statically and seemed good.
    Checked Spark Plug wires statically and seemed good.
    I can bypass fuel pump relay and get more than 50 psi
    No spark
    No Fuel unless I bypass relay, no clicking of injectors
    Compression seems good (my tool will not fit all the way down through the valve cover, however blows a screwdriver handle off the spark plug seat very well.
    I have done the 30 minutes on with key, off with key, repeat 3 times.
    Same symptoms
    Everything electrical works. Just can't get spark or fuel due to ???
    I am pretty much at a stand still, The ECM does not seem to be "triggering" the fuel pump relay.
    Any help will be appreciated.
    One more thing I forgot, the Engine Control Power Relay is energizing.
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Re: 1998 Catera Cranks, not firing, no fuel pressure.
    Just a guess, if ECM replaced then have to reprogram it at the dealership or maybe bad fuel pump.
