wont run
Results 1 to 8 of 8
Cadillac Catera and Cimarron Forum Discussion, wont run in Past Cadillac Vehicle Discussion; have a 97 catera, has signs of leaking oil cooler or cracked head gasket. It will turn over but wont ...
    oilleak is offline Cadillac Owners Member
    Automobile(s): Catera
    Aug 2012
    15
    wont run
    have a 97 catera, has signs of leaking oil cooler or cracked head gasket. It will turn over but wont fire up and start running. Its got oil, getting fuel, and has a spark from plugs, all fuses are good. Could something electrical have gone bad, or the timing has jumped? Or did something internaly break in the motor?
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: wont run
    Crankshaft Positoning Sensor. CPS. VERY common problem on a Craptera!
    Aug 2012
    15
    Re: wont run
    So that would cause the car not to run at all? Just turn over? Were is that sensor located?
    retho78 is offline Cadillac Owners Connoisseur
    Sep 2007
    1,024
    Re: wont run
    If it's the CPS, then it's right next to oil filter and the wire goes up behind the upper intake, below the wiper arms / cowl cover area.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Re: wont run
    When you replace it add some aluminum foil to extend the provided heat shielding. The wire's insulation gets cooked by the exhaust manifold. We think that's what causes the CPS to fail.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Sorry, I have to nitpick the acronym being used (but it will be informational ).
    It's not CPS. If it were, then what would cam position sensor be?
    CPS - Central Power Supply
    CKP sensor - CranK Position sensor
    CMP sensor - CaM Position sensor
    Out of curiosity, who supplied the OE CKPs for the Catera? There was a bad run of Seimens for the Northstar, the new ones are Denso.
    Jul 2008
    712
    Re: wont run
    When mine went the dealer referred to it as the CPS.
    PrimeTimeElite's Avatar
    PrimeTimeElite is offline Cadillac Owners Member
    Automobile(s): Catera 1999
    Dec 2005
    Colorado
    39
    Re: wont run
    I would have to look to be sure and I don't have ready access at the moment but to best of my recollection it's referred to as Camshaft Position Sensor, CPS, in the factory service manual and the parts stores use that terminology for the correct part for this car.
  11. Remove Advertisements
