Milky oil cap and down in pour pipe but dip stick looks good?
Results 1 to 9 of 9
Cadillac Catera and Cimarron Forum Discussion, Milky oil cap and down in pour pipe but dip stick looks good? in Past Cadillac Vehicle Discussion; Cold winter mornings maybe? Blown head gasket? No):...
    CadillacManny's Avatar
    CadillacManny is offline Cadillac Owners Member
    Automobile(s): 1999 Cadillac Catera
    Feb 2013
    Marietta, PA
    55
    Blown head gasket?
    No):
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    A milky cap can be caused by condensation in the crankcase. Take many short (less than 20 minute) trips?
    Feb 2013
    Marietta, PA
    55
    Found problem. No rubber seal around oil cap
  5. #4
    Sep 2010
    East Boston MA.
    29
    26,325
    That won't cause a milky cap, but it's a vacuum leak.
  6. #5
    Feb 2013
    Marietta, PA
    55
    Def condensation
  7. #6
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Re: Milky oil cap and down in pour pipe but dip stick looks good?
    Winter condensation.
  8. #7
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,547
    ........... or a non-functional PCV system - which is designed to prevent just that sort of moisture buildup.
  9. #8
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Don't mistake our suggestions as expertise. The mayo could be what we say but again it could be a leaking oil cooler which is catastrophic if ignored. If it were a blown head gasket there'd be overheating and loss of coolant. Mechanics unfamiliar with the L81 engine are quick to blame the head gasket. While it does happen it isn't very common. Just keep the coolant level right and you shouldn't have to worry. Still some kind of compression test couldn't hurt.
  10. #9
    Sep 2010
    East Boston MA.
    29
    26,325
    IF an HG issue was suspected, I'd recommend a block test over a compression test. Quicker, easier, and more accurate.
  11. Remove Advertisements
