Every here of someone lowering there car with the stock air ride system?
Results 1 to 6 of 6
Cadillac Catera and Cimarron Forum Discussion, Every here of someone lowering there car with the stock air ride system? in Past Cadillac Vehicle Discussion; 1999 Cadillac Catera...
    CadillacManny's Avatar
    CadillacManny is offline Cadillac Owners Member
    Automobile(s): 1999 Cadillac Catera
    Feb 2013
    Marietta, PA
    55
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    You mean using the ELC system to lower the car, or lowering it while still having ELC functionality?
    ELC is rear only. The stock rear springs are soft. They retain proper rear ride height, only with no extra weight in the car. When weight is added, the rear sags, and the bladders are inflated to compensate.
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: Every here of someone lowering there car with the stock air ride system?
    Unless the rear springs are broken!
    Feb 2013
    Marietta, PA
    55
    So technically you could manually lower or raise car yourself if you wanted
    Sep 2010
    East Boston MA.
    29
    26,325
    No. As posted, the coil springs will keep the rear at proper ride height, without the ELC system. IF you have WORN SPRINGS, and let air out of the ELC system, the rear will lower. Add a passenger or put something in the trunk, and it will get even lower, and bottom out over bumps. The rear springs, as posted, were not designed to handle any extra load by themselves.
    Even if you could use the ELC system to lower the car, ELC (again, as posted ) is rear only.
    Feb 2013
    Marietta, PA
    55
    Okay
  9. Remove Advertisements
