Front sway bar bushings
Results 1 to 7 of 7
Cadillac Catera and Cimarron Forum Discussion, Front sway bar bushings in Past Cadillac Vehicle Discussion; hello guys, i want to replace my front sway bar link bushings. how to do it ???? according my alldata ...
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    hello guys, i want to replace my front sway bar link bushings. how to do it ???? according my alldata i need to drop whole front support frame and lift engine. seriously?....... there is easy way to do it??????
    Thank you
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Hello!. Anybody ??
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Re: Front sway bar bushings
    Easy job. The drop links have their bushings already. Just lift and support the front of the car, undo the bolts securing the links, replace the links and tighten the bolts.
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    actually i was talking about Stabilizer Bar Bushing there are two of them on each side
    thank you
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    The title says sway bar bushings, post #1 says links. Which is it?
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    i just explained wrong. i already replaced both links now want to replace bushings on the bar it self
    thank you
    elbrown4183 is offline Cadillac Owners Member
    Automobile(s): 1998 Cadillac Catera
    Sep 2010
    32
    Yeah...Not hard. It is best if you can put it on a lift. It might be a bit of a small bugger to get your tools in to loosen the bolts.
    However, what I did was loosen the bolts holding the bushings down and removed the old bushings. You should see how to manipulate the hold-down bracket.
    Bear in mind, the new bushing will be stiff and you will have to use some strength to get the news one's down.
    It is pretty straight forward. Use a flashlight so you can see it well too.
  10. Remove Advertisements
