97 Catera Misfire on cylinder 3 help!!!
Results 1 to 7 of 7
Cadillac Catera and Cimarron Forum Discussion, 97 Catera Misfire on cylinder 3 help!!! in Past Cadillac Vehicle Discussion; hi i had recently bought this 97 catera that has been a nightmare i haven't had any problems with it ...
    Wes123 is offline Cadillac Owners Member
    Automobile(s): Catera
    Jul 2012
    6
    Unhappy97 Catera Misfire on cylinder 3 help!!!
    hi i had recently bought this 97 catera that has been a nightmare i haven't had any problems with it until i got a oil change then i started having oil in my spark plugs several different things I've got rid of the oil in the plugs by replacing the valve covers new spark plugs and wires new coil pack and new cps senor new fuel pump and still i get a misfire which causing my car to run rough... its only on cylinder 3 the code p0303 is the code thats shows up on my scan tool any help would be appreciated
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Go to AutoZone. And rent u at tool call compression tester gauge. Do a compression test on cylinder 1,3 and 5. And see what reading u have . My cylinder #3 is low on compression but is running fine.
    Jul 2012
    6
    Re: 97 Catera Misfire on cylinder 3 help!!!
    Quote Originally Posted by JohnJJO View Post
    I will try this first then report back do you have any idea of what a good compression reading maybe for this car?
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    I don't remember what was mine. I need to look for it. But it was around 180-190psi. And my cylinder #3 is still like 150psi. U have to do compression test on cold engine. Just look at videos on YouTube how to do it.
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Check the new plug and maybe change the spark plug wire.
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    That's true, u can swap plugs between cylinder 1 or 5. Reset codes and then see if missfire came up one thouse cylinders, if yes, well that your wire, also u can preform resistant test on wire with multimeter. If wires good swap plugs. If its not plugs. Then u can run compression test. If compression test result good. That might be your injector.
    Jul 2012
    6
    i think your right i didn't run the compression test i have pulled the injector an come to find out it was shocked so i pulled them all out and had them cleaned berryman injector cleaner i have order a new one a couple days ago an its suppose to be here tomorrow after i get that put in i will let you guys know how it went thanks for the help
  10. Remove Advertisements
