High beam malfunction...annoying...
Results 1 to 8 of 8
Cadillac Catera and Cimarron Forum Discussion, High beam malfunction...annoying... in Past Cadillac Vehicle Discussion; So, I'm driving on the freeway and my high beams go crazy and start blinking rapidly. The turn indicator stalk ...
    IvoryWhiteCatera's Avatar
    IvoryWhiteCatera is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Catera (SOLD)
    Apr 2011
    120
    So, I'm driving on the freeway and my high beams go crazy and start blinking rapidly. The turn indicator stalk is in the normal position when it happens, too. Any ideas? It gets annoying because it occurs at random and people in front of me think I'm flashing them.
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    Re: High beam malfunction...annoying...
    Check the blubs, did someone change them to HID?, look for the high beam relay, if anything you can remove the high beam blubs
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Quote Originally Posted by IvoryWhiteCatera View Post
    I think our multifunction stalks are wearing out. The springs, the contacts, the detents, etc. I have a related problem where the high beams randomly come on when the lights are on. Usually after a turn where I used the turn signal. A bit of backpressure on the stalk turns it off again. I "fixed" it using a rubber band to keep the stalk in the correct position. Had to make sure the rubber band was applying just the right amount of backpressure, too much and the high beams also come on with the flash to pass feature.
    I guess our cars are now senior citizens and we can expect some quirkyness.
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Sadly the quirky from day one! Wait until you sunroof opens on it's own!
    Apr 2011
    120
    Quote Originally Posted by kaustein View Post
    It's happened to me!
    Quote Originally Posted by investor74 View Post
    Thanks for the suggestion. At least my car isn't the only one with the problem.
    TheCrimsonKing is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac Seville sls
    Feb 2013
    I've been having the exact same issue! It only happens after making a right turn with signal. And applying back pressure usually turns them off until i have to make another turn. Get's really frustrating. I think I'll just take out the bulbs as I can go without them entirely.
    Jul 2008
    712
    I used to have an older Escort that at night, right turns signaling would turn off headlights!
    Feb 2013
    So all i did as a quick fix was pull fuse #27 and problem solved. I can certainly go without the high beams.
  11. Remove Advertisements
