Results 1 to 11 of 11
Thread: code P1870 and 1700
    inna-catera is offline Cadillac Owners Member
    Automobile(s): Catera 2000
    Mar 2012
    26
    12
    Exclamation code P1870 and 1700
    Hey guys, I need some help from all you smart caddi owners =]. So I have these 2 codes coming up and the check engine light is on. Sometimes when I drive, the sport mode (s) light starts flashing and the car BARELY accelerates. I pull over, turn off the car, turn it back on, and its fine. This has been going on for about a year now and it used to happen bout once a month but recently it happened 4 times in one day! I talked to a worker at autozone who checked the codes for me and he said that I need to replace my transmission. But I really don't think that I need to since this is not a "constant" problem but comes up once in a while.
    Have any of you guys had this problem and successfully fixed it?
    BTW... I recently had my TC and ABS light on and after getting my EBTCM rebuilt and reinstalled the lights went away... IDK if this has anything to do with it. I recently changed my motor oil...
    And one more question - Can someone tell me where is the thing to check my transmission oil? My dad and I have looked for it and just cant find it... I can't afford to take my car to the dealership so am fixing everything myself. The car has 73K on it.
    Here are the codes, and explanations I got from http://engine-codes.com
    P1870 Description
    Transmission is in 4th gear with Torque Converter Clutch (TCC) engaged and the Engine Control Moduel (ECM) has detected excessive slippage when comparing the input shaft speed to the output shaft speed
    P1700 CADILLAC - Transmission MIL Request
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    To cheak your transmission oil level, u need to raise vihicle on th both side! To level whole car. But before that u need to warm transmission to normal workings temperature. u can not just start the engine and lit it seat, u need to drive for at lease 15 miles. Then raise, on passanger side on main transmission oil pan, on the side of it u will find drain/check plug, remove it while engine is running!!!!!!!! yes Running. Before all that u need to get u one quarter of Dextron 3 transmission fluid , Not dextron 6 !!!!!!!! And hand fluid pump, cuz u may need to add some fluids , u never know ...... So its better to prepare
    Mar 2012
    26
    12
    Re: code P1870 and 1700
    I also need to change 2 of my O2 sensors but I can't figure out which one is which... I've spent at least an hour googling it and have not found any answers...
    Bank 2 Sensor 2
    Bank 1 Sensor 2
    Where are these two sensors located?
  5. #4
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by JohnJJO
    Dexron III is obsolete. Dexron Vi is superior, and completely compatible with III, it's it's replacement.
    That said, unless the fluid level is low, changing the fluid isn't going to fix the problem.
  6. #5
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    Senors 1 is before the Cat. and just after the engine and senors 2 is after the cat.(or post) furthest away from the engine, since both are senors 2, then both very rear senors are out, also there is no way to check the level on transmission, it a seal tranny, you have to rise the car up, remove the fill plug , and add fluid if needed, a more easier way to change your tran. fluid is to buy a gasket at any parts store, drop the tran pan and fill it back up,
  7. #6
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Didn't my massage was about how to check the fluid level ????.... Not about how to replace the fluid... Ha???..... That why I said "get u one quarter of dextron 3" just in case it will be low that he can add little bit yo....
  8. #7
    May 2012
    119
    all am saying is, if you going to all the trouble of raising the car, making sure it's level and pulling the plug out, you might as well buy a gasket (under$5) and just drop the pan, clean it and put it back on, and fill it up till it starts coming out and put the plug back on, that's all
  9. #8
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    No cents to do it with out changing oil filter and draining small pan that hold almost 1 quart.... And if u remove filter u will get enother half out..... So do maths $50 for oil u need to get 6 quarts of dextron 6 this time not dextron 3 cuz u going to change fluid not add yo. Plus filter gasket enother $20. If u have extra money. Do it !
  10. #9
    Mar 2012
    26
    12
    So are you saying that it would be better if I used the VI instead of the III??
    Quote Originally Posted by JohnJJO View Post
    Where would you recommend buying the filter?
    I use these places for almost everything: rockauto.com and autopartswarehouse.com
    can you recommend anything that might be better?
    ...I don't really have extra money... I'm a full time student... but If it will save my car then I will most definately do it. Do you think this will help with the "transmission slipping in 4th gear?"
    http://www.autopartswarehouse.com/sk...3-1631910.html
    is this the filter that I would need to change?
    http://www.rockauto.com/getimage/get...27-0&width=450
    or something more like this?
  11. #10
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    autozone has the trans filter and gasket.
  12. #11
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by inna-catera
    If you were doing a fluid change, yes, absolutely. Also, more and more places just aren't selling III anymore. If you just need to add some, use either, but III is a bit cheaper.
    But before you start thinking about which fluid to use...
    As I posted before, a fluid chance will do exactly nothing for a slipping transmission. Neither will a new filter. With no other codes, and the fluid at the proper level, a slipping transmission means rebuild or replacement time.
  • You may not post replies
