Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: Poor Gas Mileage
    werwer2012 is offline Cadillac Owners Member
    Automobile(s): 1999 Catera
    Oct 2012
    Brampton, Ontario Canada
    59
    35
    Poor Gas Mileage
    I have a 1999 catera and I have noticed that over the past month or so the gas mileage is getting really bad. I had it into the garage and they changed the air filter and plugs and it still is bad. I go 50 to 60 klms on a 1/2 a tank of gas and it cost me $32 to fill it up again. Can anyone give me any idea's what else they sholud check. Any help would be greatly appreciated.
    Thanks..Greg
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Welcome to the club of Low MPG. My cat can go only 240 miles on regular gas . And like 190 on premium. And I'm not flying around. Keeping my idle up to 3000rmp.
    OEM New spark plugs.
    Air filter, fuel filter
    Injectors hand cleaning and multiple time cleaners to the fuel tank was add + seafoam was preformed few times to.
    No help.
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    Re: Poor Gas Mileage
    Hello
    what you might try is start the car and have someone run the RPM,s up, at the same time go to exhaust pipe and smell the exhaust, if really is strong than your burning rich, (more fuel than needed) The most common problem to this is a bad MAF, I took mine out and bought MAF cleaner, clean it and put it back, took off all the connection to it and but them back on, it work for me, might for you,
  5. #4
    Oct 2012
    59
    35
    Thanks for the information. What is an MAF?
  6. #5
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Mass Air Flow sensor.
    I'd suspect the FPR (Fuel Pressure Regulator) before the MAF.
  7. #6
    nethic is offline Cadillac Owners Member
    Automobile(s): 1998 Catera
    Nov 2012
    Sudbury
    43
    how much to replace both those parts ? I get the same issue but I'm almost positive its the o2 sensors (which I have brand new just can't put in since I have no jack )
  8. #7
    Sep 2010
    East Boston MA.
    29
    26,323
    Never priced either for a Catera, but FPRs are fairly cheap, MAFs can get expensive.
    Why are you replacing the O2 sensors? Is the CEL illuminated? Did you pull the codes?
  9. #8
    Oct 2012
    59
    35
    I have heard that you can clean a MAS sensor. Is that something the average person should attempt?
    Greg
  10. #9
    Nov 2012
    Sudbury
    43
    Not yet, my OBDII reader is on the way so I should have the codes pulled soon.
  11. #10
    Sep 2010
    East Boston MA.
    29
    26,323
    Yes, you can clean a MAF sensor. Not difficult in any way. Buy some MAF cleaner, remove the sensor, spray it clean, reinstall. If there are any codes for MAF voltage, cleaning it won't do a thing.
    If the CEL isn't illuminated, the O2 sensors are fine.
  12. #11
    Oct 2012
    59
    35
    Thanks for the information...Greg
  13. #12
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Pass month was monitoring my mpg:
    2000 Cadillac Caters Sport with 153k miles, tire pressure was monitoring. Had full trunk of my tools, include prof. heavy jack. Newer air and fuel filter. OEM spark plug with approx. 20k on them. Engine oil Castrol GTX 5w-30 had approx. 3k of use when I started my mpg monitoring. Car was treated with Lucas and Seafoam frequently in a pass. During this time had no passengers and only me drove the vehicle.
    Results:
    Regular 87 - 16 mpg
    Premium 93 - 13.1 mpg
    Both time used Costco gas. Vehicle was driven in city only, in general keeped my foot on up to 3000rpm. But some time had to reached to 5000. I'm not crazy driver.
    I did saw the differents between 87 and 93 gas. Premium gave me better power and kind of stable. But It was not worst to lose 50 miles of driveble distance by using premium 93 gas....
    Any comments?......
  14. #13
    May 2012
    119
    umm, something up? I get better mileage with Premium than Regular, if I use Regular I get poor mileage and the engine pins, I adv about 25 mpg
  15. #14
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    wow so what to do now?.......
    since i been have this car used regular
  16. #15
    cateralover1209 is offline Cadillac Owners Member
    Automobile(s): 2001 catera sport
    Dec 2011
    34
    24
    Well in my 2001 catera sport black i been having suspicions of the coolant bridge sensors theres two sensors on the coolant bridge.One is a single wire plugged on top of it and this sensor gives you the reading on your dash.the other one is a coolant temp sensor that tells your ECU(electronic control module) when it has reached closed loop so if that sensor is faulty youre runnig open loop for a longer period of time ,witch will kill youre gas mileage try looking into those sensors there only like 12$ each and try cleaning the ccv(cranck case ventilator )
  • You may not post replies
